Author Topic: Alternator Plugs under the seat  (Read 1212 times)
Offline BeaverMatt
« on: July 03, 2021, 11:02:59 PM »
Hi Folks -
Needing a little help please.  There are three identical plugs under the seat that come from the alternator.  All three plugs appear identical and as are the three wires.  How does one tell which wire goes to which plug?  Does is matter?
Beaver Matt
2009 C14
Black
Offline BeaverMatt
Re: Alternator Plugs under the seat
« Reply #1 on: July 04, 2021, 09:09:38 AM »
An edit to my question above - the three identical plugs are under the fuel tank (the portion of the tank this under the front of the seat).
Beaver Matt
2009 C14
Black
Offline ginzburg
« Reply #2 on: July 04, 2021, 09:58:59 AM »
The manual shows that the wires are all marked BK and connect to BK.
You might look for the following to verify for yourself, but I believe the order does not matter.
3 phase motorcycle stator. Does the order matter?
« Reply #3 on: July 04, 2021, 02:47:15 PM »
I believe the stator puts out AC current so order should not matter.
Offline BeaverMatt
« Reply #4 on: July 04, 2021, 07:08:26 PM »
Thank you both for your replies!  I was thinking the same, just wanted to hear a couple other opinions agree!  Have a safe and hath 4th of July!
Beaver Matt
2009 C14
Black
