Author Topic: Valve adjustment labor cost  (Read 35012 times)
Offline kdm
  • Lakeland , Florida
« on: July 09, 2011, 07:24:32 PM »
For those who paid to have the valves adjusted -- what's a fair price ? Local dealer seems a little high.
2001 C10  - sold
2008 C14
Offline CrashKLRtoConnie
Re: Valve adjustment labor cost
« Reply #1 on: July 10, 2011, 08:24:46 AM »
I wish there was a flat rate guide for the C14. It would be nice to know how long the Dealer is given for each specific job.
Like this ...
http://cgi.ebay.com/ebaymotors/2005-Yamaha-Service-Flat-Rate-Manual-Scooter-Motorcycle-/120494250099
My guess is that a good dealer can pull off all the stuff to get to the valves, do the value adjust, put everything back in place in about 2 - 3 hours.
In the California Bay Area the hourly rate seems to be about $85 dollars and hour. (Most shops post the hourly rate in the service area).
So my guess in labor $150 - $250 + parts. Likely if you would add an oil / filter change when you open the engine and as long as the have more than 10k miles might as well do the plugs.
2008 C14 GTR1400 AKA "Connie"
Offline Tarheelbob
« Reply #2 on: July 10, 2011, 09:02:40 AM »
Seems like many of the reports here on this forum have run up to $400 for the check, with no adjustments needed. Full check with adjustments, requiring cam removal, can run in the $600 range.
Offline cRAsH
« Reply #3 on: July 10, 2011, 09:25:54 AM »
Like this ...
My guess is that dealer is accessing the valve cover with a sawzall and a big pry bar.
rokhaul is a lying scam artist
Offline kdm
« Reply #4 on: July 10, 2011, 10:25:31 AM »
Yeah, my local shop wants $650 to do the complete job,including plugs !  So ,where can I get a set of Freds videos?
Guess it's time to give it a try myself.
2001 C10  - sold
2008 C14
Offline IRULE
  • How sweet it is...
« Reply #5 on: July 10, 2011, 10:51:16 AM »
Man, have you seen this?  Just look at page 3 of the tread.  HELL NO!  NOT DOING IT.  I don't care how much, ain't gona touch it.
http://www.zggtr.org/index.php?topic=2375.30
2009 Red Buell 1125CR
1978 Triumph Bonneville
« Reply #6 on: July 10, 2011, 12:04:57 PM »
common flat rate now runs between $90-$115 / hour.
4 hours on this job??  correctly done, first time shot, will take even an experienced (i.e. having actually done THIS bike before) tech, a minimum of 4 hours, that is if they have the parts and shims at hand....add in doing an oil change, air filter, throttle body synch, and you add in another hour + or so.
Hazardous waste disposal, and shop fees for oil, cleaning rags, sealants, etc., will add on another $75. Add in the cost for the valve cover gasket (they WILL charge for a new one), plugs, oil, filters, and you have another $160-$180.....
so in the end, the prices they are giving are in line, IF they actually do the services, and replace the parts.
This my friends is why I don't believe a lot of the reports of "your valves are within spec" I hear soo many times.
I have my work area setup with every tool I need, and have worked in the industry doing massive teardowns and repairs, these times are realistic, and don't take into account the distractions clearly arrising in a shop on a daily basis (change this tire, the customer is coming in in 2 hours, and then empty the garbage....)
so, this ain't a simple job, but on the other hand, it ain't rocket science. 8)
Offline gflint
« Reply #7 on: July 10, 2011, 12:50:09 PM »
Many shops on a job like this will give you a flat rate that can be negotiated.  If you go by shop time it can get a bit too interesting.  Having done this for a living many years ago the time to do a big job is greatly influenced by interruptions, lack of knowledge if it is the first time, finding borrowed tools, finding space to put all the pieces-parts removed from the bike to get to where you need to work and so on.  I would call this a big job for two reasons - lots of stuff to remove to just get to the initial measurements and the need to remove cams to make the adjustments if required.  For those of you planning on doing this for the first time and if you do not have a lot of mechanical experience, it is not a hard job.  Get the video and take your time.  It does require the correct tools and lots of time.  Plan a couple of days not counting the waiting for the correct shins to come in.  If you do not have a lift it can be a real back killer.  I will pay $400 -$600 to not have to walk like a hunchbacked gnome for a week afterwards.
« Reply #8 on: July 10, 2011, 01:17:47 PM »
hit the nail right on the head there...lots of room is needed....and a lift is definatly a ++++100
Offline jjsC6
« Reply #9 on: July 10, 2011, 02:19:50 PM »
I have no doubt that this is no 2 hour job even for an experienced mechanic.  But a couple of you have mentions "distractions etc".  I hope we are not expected to pay for the time spent on distractions, or even looking in the book to see how to do it.  The reason we pay trained & certified mechanics is that they are supposed to know how to do the job we are paying them for.
Jim
2010 Concours - Sold Feb 2013
Current bikes....
« Reply #10 on: July 10, 2011, 04:27:40 PM »
There IS a flat- rate guide for the C-14, dealers have it, or at least my local dealer does. They list a valve adjust as taking 3.2 hours, including lifting the cams and changing shims as required. My dealer doubles that estimate and still expected to miss the mark by quite a bit. Good call on their part too.
As for doing a valve lash check and adjustment on a C-14 in 2, 3 or 3.2 hours, there is no way that can be done IMO. I have done this job several times now, have pneumatic tools and can move along quickly and there is simply no way that this job can be done in that amount of time. At least not 3.2 Earth hours (Jupiter hours, maybe). There is just too much work to be done getting to the valve cover, and checking all of the clearances and writing that down is more than a nine minute job in itself.
I would be impressed if it could be done in one day (8 working hours, Earth hours). By that I mean starting on a cold but complete and running bike at, say, 8:00 AM and having a finished, fully assembled C-14 at 4:00 PM that day (5:00 PM if you want to have lunch and lick your wounds a bit).
But in anything even approaching 3 hours.... not in this lifetime in my opinion. It reminds me of an old Archie Bunker like about Meathead: 'He eats so fast sparks fly from his knife and fork.' Well, anybody who can pull apart a C-14, remove the cam(s) to swap even one shim, reassemble the bike to a fully finished, correctly running and looking state would do more than just make sparks- that person would have to have a wand absolutely full of magic.
Like this ...
Offline BudCallaghan
« Reply #11 on: July 12, 2011, 10:54:45 AM »
This was kdm's reply to Tarheelbob's post:
I sent this PM to kdm:
I have a set of Fred's C14 repair videos that I will never use.  Complete, in case and ready to ship.  You can have them for $60.00 and I'll pay the postage.
kdm promptly replied to the PM stating that he wanted them and requested method of payment.  I sent PM with requested information but have yet to hear from him.  PM's don't always reach their destination so I'm posting this reply.  If you still want the videos you'll need to answer soon as I am about to begin a long vacation.
Offline ridingfar
« Reply #12 on: July 12, 2011, 11:25:55 AM »
Ok Boys - Time to man up and face the realities of the situation:
1 – You own a motorcycle that’s a PIA to service; not particularly difficult, just tedious and requiring a bit of precision and a fair amount of time.
2 – NO ONE, and I mean NO ONE cares as much about the proper maintenance and operation of your bike as you do.
3 – Due to #1 and #2 the probability that a valve check and adjust-to-center, and all that is involved to perform this work, will be done competently, with good attention to detail, is very low….at any price/labor rate.
Your choices are:
-   Do the work right yourself
-   Put up with high shop prices and poor workmanship
-   Get an easier/cheaper bike to maintain.
We now return you to your regularly scheduled whining…..
Courtney in St. Louis
The power of accurate observation is called cynicism by those who have not got it.
    - George Bernard Shaw
Offline gflint
« Reply #13 on: July 13, 2011, 09:23:18 AM »
The good thing about going to the same shop for 20 years is you get to know the mechanics.  If the shop does not have a large turn-over I would say it is safe to trust the job to them.  If the shop does not keep a mechanic for longer than a year or so, do the job yourself or find a better shop.  I know the guys at my shop and they know a lot more than I do now.  And they have a lift.  And the shop is spotless, unlike my rather crowded garage covered in Golden Retriever hair.
3.2 hours?  That must be time not including removal of all the junk surrounding the valve cover.  3.2 hours would be a good time on a naked bike.
Offline sherob
« Reply #14 on: July 13, 2011, 09:34:32 AM »
I paid $325 or $350... can't remember now.  I also had them pull the plugs while they were in there too, since they had all the plastic off.  That saved me a few bills since the plastic was already off.  They swapped shims with ones they had on hand, no charge for those.
Rob
Offline gflint
« Reply #15 on: July 13, 2011, 11:24:35 AM »
$350!!  That would almost make it worth the ride from Montana.  Is that the ride it in - ride it out price?
Offline sherob
« Reply #16 on: July 13, 2011, 11:35:53 AM »
Yes.  Dropped it off on Friday... was ready the following week on Thursday.  They did the valves, plugs... also had new rubber put on, oil and rear drive serviced too.
The bike has to sit, be cold, before they rip it apart for the vavles.  I also had to make an appointment, make sure they had the time to do it.
Rob
Offline C1xRider
« Reply #17 on: July 13, 2011, 02:06:34 PM »
Sounds like they took it as a "back burner" job.  I was talking to the owner of a local shop about his rates, and he says the bigger the job, the lower his shop rate.  If they could have the bike for several days or even a week, then they can work on it between "emergencies".  Plus, if a guy can focus on one big job for longer, he's more productive too.
Offline sherob
« Reply #18 on: July 13, 2011, 03:11:41 PM »
Yeah... IIRC, they had something come in that needed to get fixed in a hurry while my bike was being worked on... a Mule 4x4, something along those lines.  Was fine with me since I was willing to wait a week anywho... I knew if I did it myself, it would have taken longer... much longer.  :o
Rob
« Reply #19 on: July 13, 2011, 04:03:20 PM »
Agreed- the 3.2 hour estimate is ridiculous even though it is what Kawasaki calls for, at least according to my dealer. I would not think a dealer would minimize the amount of time estimated to do the job. ??  I think the basic problem is that the flat rate times in the service manual are used to set the price for warranty work, and the mfgs. would all lean toward the low end, perhaps even the ridiculous end, of the possible schedule.
There are absolutely good dealers with good, maybe even great, service people available. It may not be the majority but they are around. My local dealer has had the same crew for many years and I would trust them to do anything / everything to one of my motorcycles.
I spend a little time on the FJR forum and find it very interesting that while the C-14 has the reputation for being difficult to do a valve lash check and adjust on (and I believe that is true), the prices the Feejer owners pay is similar to the C-14 prices it seems. There are a lot of $400 to $600 valve lash charges being reported of FJRs but very few in the $300 range.
