Author Topic: 2010 Buzzing noise from the front.  (Read 1288 times)
Offline Bzotya
« on: June 09, 2021, 05:23:17 PM »
I'd like to have some help with a strange noise coming from the front while riding. Sounds like it a pump or a broken pump noise. I'm wondering if it's some kind of servo pump just guessing. Any suggestion welcomed. Thanks
Offline jwh20
Re: 2010 Buzzing noise from the front.
« Reply #1 on: June 09, 2021, 05:30:48 PM »
Is it engine speed related or wheel speed related?
Offline Bzotya
« Reply #2 on: June 09, 2021, 05:35:54 PM »
Sounds like brake related. It sounds like an old car with a broken power steering pump of course not that loud.
« Reply #3 on: June 09, 2021, 06:59:00 PM »
So it is occurring when braking or just coming from the front brake area? Or what else might you mean by brake related sound. (I have no clue what an old car with a broken steering pump sounds like)
Offline jwh20
« Reply #4 on: June 09, 2021, 07:58:56 PM »
It would really help to have a complete description of when/where/how this happens, what, if anything, causes it to vary.  The information so far doesn't really give much to go on.
The only things moving out front are the tire/wheel/brake rotors.  So things like the wheel bearings, the brake pads might be an issue.  Is it possible that there is something loose like the front fender?
« Reply #5 on: June 10, 2021, 04:19:50 AM »
I had a set of brake pads that buzzed for awhile but I don't remember the brand unfortunately.
Offline Bzotya
« Reply #6 on: June 10, 2021, 04:43:58 AM »
I guess my next step is replacing the pads if that would be the culprit.
« Reply #7 on: June 10, 2021, 12:51:59 PM »
does the sound change when you apply the front brake?
« Reply #8 on: June 11, 2021, 06:49:08 AM »
Cicadas?
« Reply #9 on: June 12, 2021, 06:35:56 AM »
If he's in the DC area, possibly.
Offline Bzotya
« Reply #10 on: June 16, 2021, 07:32:03 PM »
Update on the buzzing noise. I replaced the the front pads, cleaned the calipers and pistons. Noise is gone. Thanks for all help.
« Reply #11 on: June 16, 2021, 07:39:30 PM »
 :chugbeer:
