Author Topic: Switched Power  (Read 1185 times)
Offline Coomers
Switched Power
« on: May 04, 2021, 06:28:26 AM »
Good Day,
I'm looking to hardwire my GPS and was wondering if Kawasaki supplied a switched power source plug or do I have to tap in somewhere on my 18 Conny.
Thanks,
Re: Switched Power
« Reply #1 on: May 04, 2021, 08:43:00 AM »
There is a (switched power) accessory lead provided. it is located below/forward of the glove compartment.
Sometimes hard to find as it is in the bundle covered by a rubber cover.
Offline Coomers
Re: Switched Power
« Reply #2 on: May 05, 2021, 05:37:08 AM »
Thanks Ted,
Offline Mr2U
Re: Switched Power
« Reply #3 on: May 05, 2021, 02:58:27 PM »
I have a 2009, and I pulled off the upper right side fairing, and tapped into
the 12v power outlet supply wire, for my radar detector.
it then goes on and off with the ignition.
Re: Switched Power
« Reply #4 on: May 05, 2021, 05:22:41 PM »
The accessory lead on the left side does exactly the same thing.
Offline Coomers
Re: Switched Power
« Reply #5 on: May 10, 2021, 08:51:21 AM »
Found it, nice that they also provide a ground.
