Author Topic: ZX14 Fork Swap completed  (Read 1652 times)
Offline bmidd
« on: March 20, 2021, 10:54:34 PM »
Fork swap from a 2017 ZX14 SE is completed and I got a good 120 miles in today to get it sorted out. The fork oil level is 110mm and I used Maxima 125-150 7wt oil. I swapped out the springs with 1.2kg/mm and free sag is 30mm+5mm rider for a total of 35mm. The forks are pulled 7mm through the top triple. I set the compression in the middle(8 clicks out from full) and adjusted the rebound from there. Went about 60 miles and got things warmed up and had to add 3 more clicks of rebound when the oil warmed up. The ride is more compliant than the C14 forks were and now every bump doesn't feel like a sharp edged bump or thump. ZX14 has more fork travel and the bottom out is 13mm from the lower and I had a good 10-12mm cushion from that. I'll push it a little more next ride and make adjustments from there. Oh yeah, the Brembo calipers look nice too!
Re: ZX14 Fork Swap completed
« Reply #1 on: March 21, 2021, 07:54:08 AM »
With the forks 7mm above top triple are they touching the bottom of the risers. I can't remember how far up mine are but I had to buy a 1/2 inch spacer for my risers.
« Reply #2 on: March 21, 2021, 09:23:05 AM »
Well done!
Looks good.
Apparently the ZX forks have both compression and rebound adjustment?
Offline bmidd
« Reply #3 on: March 21, 2021, 12:25:23 PM »
I have the wedges under mine, no riser blocks and I still have about 3-4mm clearance left.
Offline bmidd
« Reply #4 on: March 21, 2021, 12:26:37 PM »
Well done!
Looks good.
Yes sir, they do. That was the primary intent for switching. I had an old set of 07-08 ZX14 forks, but ran across this whole front end from the Brembo equipped 2017 and couldn't pass it up.
Offline CDII
« Reply #5 on: March 22, 2021, 05:31:11 AM »
Nice! Glad more of us are doing this. It's a worthwhile mod.
« Reply #6 on: March 22, 2021, 09:38:22 AM »
I have not seen the wedges but I assume they change the angle as well as raise the bars. The way I came to install the ZX forks was I sent my OEMs to GP Supension for cartridges. They told me one of my forks was cracked so I bought a set of ZX14 take offs on Ebay and had them sent to GP. I was told the ZX forks were 10 mm longer than the ZG and should be raised that much. I had to buy the risers to do that. Also, The ZX forks were not ABS so I had to mill and drill and tap the right fork bottom to accomodate the speed sensor.
Those Brembos do look nice!
« Reply #7 on: March 22, 2021, 03:37:10 PM »
Yep, that is exactly how they work.  They are very thin on the inside and moderately thin on the outside.  I have them, in addition to risers.
