Author Topic: Eco map?  (Read 1487 times)
Kalya
Eco map?
« on: August 13, 2020, 03:08:28 AM »
I have a 2016 C14, I am thinking about a flash for power, but  I  would like to keep the eco map that  I use to cruise. Is the ECO Map still there after the flash?
« Last Edit: August 13, 2020, 11:18:20 AM by Rick Hall »
Offline Steve in Sunny Fla
    • Shoodaben Engineering
Re: Eco map?
« Reply #1 on: August 13, 2020, 06:17:08 AM »
if the 02 sensor has been deleted in the flash then the ECO map is useless . If you want to continue to have the different power and ECO maps on a 2015+, then you will need a flash that uses the 02 sensors. To my knowledge, only Shoodaben has that option.
