Have you ever experienced a problem with the battery, terminals, connectors, grounds, etc that caused the C14 to act strangely when trying to start or caused the bike to die after being started? (Read first post before voting)
Owned C14 less than a year- NEVER had such issue
Owned C14 2-6 years- NEVER had such issue
Owned C14 7+ years- NEVER had such issue
Owned C14 less than a year- HAD the issue
Owned C14 2-6 years- HAD the issue
Owned C14 7+ years- HAD the issue
Author Topic: Poll- unusual voltage/kipass issues  (Read 2444 times)
« on: July 11, 2020, 06:36:38 AM »
I am curious.  We all know the C14 seems especially sensitive to voltage/current/terminal/battery/ground issues.  Not your normal type where the battery is weak or something and it just doesn't start, or it just clicks, or it properly warns that the voltage is low.  But strange/unusual behavior like the the display freaking out, or seemingly random, unusual error messages, or similar experiences that would lead a typical user to NOT understand it was a simple problem...  Then one discovers, later, it just was a weak or defective battery, or a poor connection to the battery or frame grounds.  THIS SHOULD NOT be confused with the other issue of the key/knob just not working (and requiring the infamous "K Rock" solution of banging on the knob to release the switch).
This has happened to me twice- once where I had no idea what was going on and the other where I was familiar with the problem so I knew what it was.  The second time left me stranded away from home for a while (where I had to remove the battery and clean/tighten the connections).
I set the poll to allow changing of your vote, in case you make a mistake, or as this thread gets old you need to change it because it then happens to you.  Thanks for participating!
Over the many years, we have seen lots of such posts.  I am just curious to collect some information to see how many of us have seen such a problem.  So I thought a poll might be interesting.
Offline PH14
Re: Poll- unusual voltage/kipass issues
« Reply #1 on: July 11, 2020, 09:40:05 AM »
I voted. 7+ years and no issues, but, if I have an issue after voting, I will blame you.
« Reply #2 on: July 11, 2020, 10:26:29 AM »
Ditto
« Reply #3 on: July 11, 2020, 11:27:14 AM »
LOL!
That does seem to be the way things work, sometimes.
« Reply #4 on: July 13, 2020, 01:49:56 AM »
I've never had an issue, but after hearing various peoples issues I modified my earth connections by adding a copper crush washer between the battery cable and the frame. I then smeared it all in silicone grease to prevent corrosion. My Motobatt battery terminals are brass so not worried about those.  ;D
« Reply #5 on: July 13, 2020, 06:50:19 AM »
No issues for me in 7+ years (11+ actually) with my C14. I remove my battery during the winter months and the only issue that I ever had with it, other than mice in the battery compartment, was a nasty corroded negative battery post on the OEM battery. I replaced it, no problems since that issue.
Motobatt is what I replaced the OEM battery with with, back in 2015.
« Reply #6 on: July 13, 2020, 02:59:47 PM »
Been a very long time since we have had an 'I like KiPass' / 'I hate Kipass' thread (regardless of the actual wording used on this survey). I kinda' miss it..... :'( The image of so many riders beating the $*!( out of their ign. switch housings with a rock has always brought me a great deal of amusement, especially when they are trying to 'fix' a flat tire or a missing saddle bag or similar.
Somewhere out there, Ole' Bob has had a shiver go up his spine when this thread was posted.  :rotflmao:
« Reply #7 on: July 13, 2020, 03:19:15 PM »
With only 14 responses so far, we might not learn all that much.  But, let's give it some time.
« Reply #8 on: July 17, 2020, 01:24:22 PM »
And for those of us being here since dirt, we know this Bob and actually have ridden with him..
I only had it happen twice and both times after washing the bike.  Both times were fixed by beating it into submission and cursing it with ever foul word I knew.  However, once I had Brian's 'fix' installed, it never did it again...knocking on wood for my friend who owns it now.
Offline PH14
« Reply #9 on: July 17, 2020, 02:33:14 PM »
Wait, you WASH your bike?  :yikes: No wonder!
« Reply #10 on: July 18, 2020, 12:10:26 PM »
Only those two times.  I don't need lightening to hit me more than twice to learn something.  BTW, this does not apply to the Indian which I have washed significantly more than twice.
Offline DGOLD
« Reply #11 on: July 18, 2020, 12:48:28 PM »
I have had my 2010 since April 2010. About every other year I find the battery connection loose or some invisible corrosion will cause multiple issues. So far it has always been fixed by a thorough cleaning and reassembleing.
Symptoms seem to vary from no juice to weird dash messages.
2010 c14(current mistress)
« Reply #12 on: July 18, 2020, 04:24:04 PM »
So, in other words, you have a KiPass problem about every two years?
« Reply #13 on: July 19, 2020, 05:17:42 AM »
Interesting you say that...   Battery/voltage issues appear to be in most modern motorcycles these days and Indian is no stranger to that.  Terminals get loose and batteries go bad.  Small drops in voltage can cause all kinds of havoc.
Offline DGOLD
« Reply #14 on: July 19, 2020, 10:13:49 AM »
Never had kipass issue . My issues were always electric as in kipass my key moves into start but then the bike won't start or I get strange error messages or the bike will stall at random times.
I have the kipass rescue switch/fuse that I only ever needed to use when I didn't want my older boys to borrow the bike.
Offline PH14
« Reply #15 on: July 19, 2020, 06:54:28 PM »
 :yikes: He has gone to the other side...the clean side, but the other side nonetheless.
Offline PH14
« Reply #16 on: July 19, 2020, 06:55:19 PM »
« Reply #17 on: July 20, 2020, 07:41:43 AM »
LOL...
