Author Topic: techmount accept ram cradle ??  (Read 8537 times)
Offline JS_racer
« on: July 07, 2011, 04:02:18 PM »
have a ram stem mount, want a mcl stem nut with ram ball super bad but still am unable to purchase because of production problems. if i add a techmount, will my ran cradle for my gps fit ?? its a tomtom. also color Titanium or Silver ??
thanks.
Re: techmount accept ram cradle ??
« Reply #1 on: July 07, 2011, 07:52:04 PM »
I'm a little confused by your question, but I will attempt to answer it anyways...
If you buy a Techmount made for the C14, yes you can mount RAM components by securing one of these to the Techmount:
http://www.ram-mount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045050051056/Default.aspx
As for the color, I've only seen Techmount available in Titanium.
For about the same price (well a little more), you might consider one of these with a RAM ball mount:
http://www.murphskits.com/catalog/product_info.php?cPath=130_133&products_id=282
Offline JS_racer
« Reply #2 on: July 08, 2011, 04:03:16 AM »
http://www.ram-mount.com/Portals/0/Skins/NationalProducts/images/ramholto5iu1.jpg
thats the cradle i have, will it mount to the techmount ?
http://www.techmounts.com/products/index.php?page_function=detail&product_id=177
no thought about risers, I'm 5'9" and the bars seem good, i think.
thanks for the time,
Joel
« Reply #3 on: July 08, 2011, 05:08:22 AM »
I have this RAM cradle and it bolts up perfectly to my TechMount. The cradle even came with the proper screws for the job. I bought the TechMount in silver and it looks fine. It's not the exact same color as the handlebars though, close but not an exact match. I don't know if the titanium is an exact match or not since I've not seen it in person. You want a pic?
I looked at the cradle that you have and I'd say that to me it looks like it would bolt right on the TechMount.
Offline MrFurious
« Reply #4 on: July 08, 2011, 07:01:49 AM »
I ended up going with the riser mounted RAM ball setup (Heli risers but very similar to Murph's in the link above) as I wanted a set of risers anyway and it was a no-brainer to incorporate the RAM mount rather than having to purchase a separate mount.  This setup gives you a lot more flexibility in positioning and height (with different length arms) so you can get it up in your line of sight while still being able to see your gauges.  You will need to purchase a ball adapter for the rear of your cradle though if you opt to go this route (see OregonLAN's first link above for the proper adapter).
Here's a shot of my setup from eye level in the riding position with the Heli risers, 6" RAM arm and Garmin GPSMap 60CSx.  My Garmin Nuvi 1390T sits about an inch higher, mainly due to the difference in where the ball adapter bolts onto the cradle.  One nice thing about the Heli risers I got is that there's a PowerLet outlet in the left riser so my GPS's power cord is super short and won't get tangled up in anything.
Jim B.
COG #9642
2009 C14 - Black - Non-ABS
Insanity is not as easy as I make it look!
Offline Truerider
« Reply #5 on: July 08, 2011, 08:15:08 AM »
You may want to consider this item also.
As you can see by the picture it has numerous mounting holes for your cradle.
Its very handy,for taking your device on and off the bike.
http://www.techmounts.com/products/index.php?page_function=detail&product_id=156
Offline JS_racer
« Reply #6 on: July 08, 2011, 12:53:37 PM »
http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=46_59&products_id=260
sweet!!! been trying for what feels like a year to get one of these setups.
thanks for the time guys,
Joel
 :( just got off the phone, looking like no chance in the near future.
« Reply #7 on: July 08, 2011, 03:08:14 PM »
Is that just a cap?
If you could find something large enough to replace the cap with (using the same threads), you could probably drill out the center and tap it to accept the RAM ball post.
Just a thought...
Offline JS_racer
« Reply #8 on: July 09, 2011, 04:17:13 AM »
Is that just a cap?
Just a thought...
its a replacement nut, so you take the stock nut and replace it with this one. your idea is the same concept.  :)
i have a stem mount setup now, its http://www.ram-mount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045051052050085/Default.aspx but its a pain if i need to get the stem nut off. otherwise it works well.
Offline RedBombardier
« Reply #9 on: July 09, 2011, 12:10:09 PM »
Joel
I use the quick mount adapter also... it works slick!
Chris from the Big "D"
COG# 9361
AMA# 672853 Life
2009 Candy Diamond Red C14, Guhl. Delkevic
Offline JS_racer
« Reply #10 on: July 09, 2011, 02:10:13 PM »
say if you could help the slow folks  ;) how does this work. i cant seem to find any info on it.
i did get a call saying my cradle will fit perfect on the round mount.
thanks,
Joel
« Reply #11 on: July 10, 2011, 07:50:25 AM »
thanks,
Joel
You mount your cradle to the quick change adapter and this allows you to pop your GPS/cradle/adapter off the TechMount in a snap and stow it away for safe keeping. It's handy if you have more than one device that you would like to use with the TechMount. Of course then you need a adapter/cradle for each device. I only use one device, my GPS, with the TechMount so I don't need a QC adapter. I just pop the GPS out of the cradle for safe keeping.
