Author Topic: Anyone used an oil additive to stop an oil pan leak?  (Read 1658 times)
Offline KretonsLC
« on: July 16, 2019, 07:21:19 AM »
My '12 Connie developed a small oil leak on a recent tour and I've determined it's coming from the oil pan.  I've read about products like Lucas Oil and Blue Devil oil additives being effective for small leaks, but haven't found much about them being used in bikes like ours.
Does anyone have any experience with these products?
Offline kzz1king
Re: Anyone used an oil additive to stop an oil pan leak?
« Reply #1 on: July 16, 2019, 11:48:04 AM »
You sure it's not valve cover or cam sensor O ring? I wouldn't count  on any additive.
2010 CONCOURS
1974 Z-1
Offline KretonsLC
« Reply #2 on: July 16, 2019, 01:23:26 PM »
The valve cover, cam sensor area, and whole upper part of the engine are dry as a bone.  It's definitely the oil pan.  It developed while on a tour and that's where a service guy said it was leaking from.  When I got home I cleaned everything up and have been monitoring where the oil is coming from and have confirmed what the service guy said.
« Reply #3 on: July 16, 2019, 02:23:30 PM »
Saw the question asked on the other forum also..
simply NEVER ADD ANYTHING IN THE CRANKCASE, THAT IS NOT PURE OIL....
you will ruin your clutch.
find, and fix the leak, there is no "band-aide"..
« Reply #4 on: July 16, 2019, 03:07:45 PM »
I am no mechanic, but I would agree with MOB- oil additives might or might not work but can cause more problems than they seek to solve, especially on a motorcycle (and especially on a modern one like ours).  I would avoid additives and try to fix the leak the right way.
« Reply #5 on: July 16, 2019, 03:49:16 PM »
What he said....
Offline ginzburg
« Reply #6 on: July 16, 2019, 04:24:47 PM »
Perhaps you changed your oil before this tour. Different oils have different additives such as seal swellers and conditioners already. Maybe you changed to something with less additives and that caused the leak.
Offline connie14boy
« Reply #7 on: July 16, 2019, 11:18:51 PM »
I wouldn't even ride the bike until that is fixed- you and Connie will be really sad when any oil hits the rear tire.
Offline KretonsLC
« Reply #8 on: July 17, 2019, 07:10:36 AM »
I've thought about that.  The dealer actually changed the oil when I had them check the valve clearances a few weeks before the tour, even though I didn't request they do so.  Even though I wasn't charged for it (on the invoice anyway), I doubt they used the Motorex Top Speed 4T that I use.
I just changed it yesterday using the Motorex, so will see if that helps.
