Author Topic: Front and rear axles same diameter?  (Read 1308 times)
Offline kzz1king
« on: May 22, 2019, 09:29:45 PM »
Going to try making my HF tire more user friendly. I need the axle  diameters to do so. If  same I will just measure the rear one. Thanks
Wayne
2010 CONCOURS
1974 Z-1
Offline Michelle
  • Saving the chubby unicorns
Re: Front and rear axles same diameter?
« Reply #1 on: May 23, 2019, 02:30:57 AM »
Without breaking out the micrometer - rear axle is 20 millimetres. Front is 25. That'll be 25/32 inch and 63/64 inch if you're reading this in black and white.  ;)
Glitter White 2010 1400GTR
Windsor Green 1997 GTR1000
« Reply #2 on: May 23, 2019, 01:33:26 PM »
Michelle, are you certain about that?
I know the shoulder {at the ends of the front axle} are larger, but I thought the Inside diameter of the bearings were the same?
Update; Michelle; I looked at images on Ebay and I think you  are correct.
             kzz1king; What are you thinking to do? I'm wanting to do something similar to my HF tire changer.
« Reply #3 on: May 23, 2019, 04:22:59 PM »
BEARING DIAMETERS ARE AS FOLLOWS;
FRONT
601B6005UU   BEARING-BALL,#6005UU
Dimensions - d (inside diameter)   25mm
Dimensions - D (outside diameter)   47mm
Dimensions - B (width)   12mm
REAR
601B6304UU   BEARING-BALL,#6304UUC3
Dimensions - d (inside diameter)   20mm
Dimensions - D (outside diameter)   52mm
Dimensions - B (width)   15mm
with that said, and to make the H/f tire machine happy, you want a 3/4" threaded rod, which will work on both wheels just fine.
The H/F I have, is actually threaded 22mm, but a 7/8" bolt, with a wrap of teflon thread tape, will thread into it...
I made a screwed in adapter for mine, and a pals, by elding a 3/4" SAE nut, to the head of a 22mm bolt, and it allows me and him to insert a piece of 3/4" all-thread, to use as a center post... with common nuts and washers.
Offline kzz1king
« Reply #4 on: May 24, 2019, 09:37:20 AM »
Thanks MOB. That's what I will do.
2010 CONCOURS
1974 Z-1
Offline kzz1king
« Reply #5 on: June 06, 2019, 06:54:46 AM »
 Update. Following Mobs direction on HF mods improved the process tremendously.  I used to just stick a old lug wrench in the center. The Mojo lever likes the solid center much better. Great mod.
2010 CONCOURS
1974 Z-1
