Author Topic: headlights not working?  (Read 4455 times)
Offline hank
« on: April 11, 2019, 06:49:19 PM »
On the way home tonight, headlights stopped working, all other lights work fine just not low/high beam checked fuses under seat and all are fine none blown. Any thoughts??
Re: headlights not working?
« Reply #1 on: April 11, 2019, 07:00:14 PM »
relay?
Offline hank
« Reply #2 on: April 11, 2019, 07:54:19 PM »
Do you know where that is located?
Offline chap
« Reply #3 on: April 12, 2019, 08:06:30 AM »
The relays are under the cover at the front (top) of the tank. Held by 3 screws. There are a number of relays there.
2010 Concours ABS = Blue
2003 Concours - Red (sold)
« Reply #4 on: April 12, 2019, 09:14:47 AM »
What year bike and has anything aftermarket been done to the lighting system?
In poking around with Google, it could also be a bad ground junction.  They tend to corrode over time but if it's a newer bike that may not be the case depending on the climate conditions and where it's kept.
« Reply #5 on: April 12, 2019, 09:42:48 AM »
Also check the 10A fuse #2 (headlight relay fuse)in the same box as the other headlight fuses you checked.
Seems unlikely that both relays would go bad unless they share a common grounding point that's gone open. However, if the ground on those checks good, then I'd listen for clicking coming from the relays as you activate the high beam/ low beam switch (this of course after you bump the starter switch but don't actually start the motor). If no activation clicks are heard at these relays then check fuse #2 10A in the same box as the two headlight fuses that were previously checked. The other common points of failure up stream are the actual switch on the left bar and the latching headlight relay under the seat in the relay box....and of course the interconnecting wiring in between these.
The power to the bulbs flows this way: From fuse #2 The latching headlight relay supplies power to the bar switch (only after the starter button has been at least bumped) , the bar switch then selects which relay to activate,either the low beam or hi beam relay.
Best wishes in tracing this gremlin.
« Reply #6 on: April 12, 2019, 02:56:56 PM »
Have you no service manual?
« Reply #7 on: April 12, 2019, 03:39:04 PM »
I suspect most don't.  But it is worth the price, just averting one dealer service charge pays for itself.
Offline hank
« Reply #8 on: April 12, 2019, 08:42:32 PM »
Talked to my buddy at the kaw shop and he said it was a replay, so will get that taken care of glad for that kaw warrenty worth every penny :)
« Reply #9 on: April 13, 2019, 01:13:55 AM »
Let us know how it works out.
