Author Topic: Gas Cap Key  (Read 9775 times)
Offline SmokinRZ
Gas Cap Key
« on: August 09, 2018, 05:57:59 AM »
Hello, I am about to take a week long trip and would rather not fumble with the key in the FOB and would like to keep a key in the glove box of my 08.  Will I have problems finding a key blank at my locksmith or having the key cut from the FOB key?  Thanks
2008 Concours
2005 Concours (gone)
1992 Concours (gone)
1998 R1100GS
Re: Gas Cap Key
« Reply #1 on: August 09, 2018, 10:44:09 AM »
I don't think so, I didn't for the gas cap and saddle bags. However most key blanks that match the key profile will have too large of a head to also be used in the stove knob section. If you also want to have a backup for that as well be sure to get out a grinder and test fit the spare key in the stove knob area before you leave on a trip. It was more difficult for me to find a blank for the GIVI top case than for the C14.
There are two different keys used (A & B) so a blank that might work for one C14 may not work for 50% of the rest of them.
You might want to start the locksmith off with one of the below blanks.
 Ilco KW14; Ilco KW14R; Ilco X254 ; Ilco X255; Ilco X258; Ilco X259
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=2ahUKEwjH4fGht-DcAhUOYK0KHeokDaYQFjACegQICBAC&url=http%3A%2F%2Fwww.ilco.us%2Fmedia%2F770046%2Fv4%2FFile%2Fmotorcycle-key-blank-reference.pdf&usg=AOvVaw3OsvUX1406DKX-k2ExG2UE
Re: Gas Cap Key
« Reply #2 on: August 09, 2018, 02:47:02 PM »
I went to a locksmith and had some made.
Not a problem.
Ted
Re: Gas Cap Key
« Reply #3 on: August 09, 2018, 03:23:52 PM »
Not a problem.
Same here.  The resulting key was too big (huge head, sticks way out of the locks too), but works fine.
Offline kzz1king
Re: Gas Cap Key
« Reply #4 on: August 09, 2018, 07:50:21 PM »
I had a couple made and cut the heads down and epoxied them in oil cap Lids. I leave  mine in my saddlebags all the time. If I feel I need to secure things were closely I just drop them in the cubby. It's real Handy to reach for one when I fill up for gas.
2010 CONCOURS
1974 Z-1
Re: Gas Cap Key
« Reply #5 on: August 10, 2018, 08:47:00 AM »
The key I initially bought from the locksmith was also long like the one that maxtog has.
I went back to the locksmith and he found a shorter blank to use. Works perfectly.
I did the same as kzz1king, but used Radio knobs instead of oil caps.
I suspect we both built them so that they barely stick out of the top of the bags.
Not noticeable at all. I tell folks mine are knobs to adjust the stereo.
        {Surprisingly, most believe me).  :o
I use a leather key case that I put my Fob, lock keys, spare trunk keys, and keys for the gas tank in.
Very handy..
NOTE: I'm always concerned I'll loose my FOB, so In the key case I have a dog tag with a note saying "If found, call ###-#### for $100 reward".
Re: Gas Cap Key
« Reply #6 on: August 10, 2018, 02:46:42 PM »
Not a bad idea, Ted.  Although, with me if you found my fob it would have my pants attached to them.
Re: Gas Cap Key
« Reply #7 on: August 10, 2018, 05:37:52 PM »
caught in the zipper?
Offline tweeter55
  • Ride Hard...Ride Safe
Re: Gas Cap Key
« Reply #8 on: August 10, 2018, 05:57:19 PM »
First time I've heard it called that. :rotflmao:
Offline katata1100
Re: Gas Cap Key
« Reply #9 on: August 11, 2018, 09:49:59 AM »
Local locksmith has blanks that will work, just with different top. I have one from dealer, drilled a hole in it to attach Del Sol ( changes color with sunlight ) key chain.
I keep that in the gas cap on long trips, along with a cc in the glove box.
Offline SmokinRZ
Re: Gas Cap Key
« Reply #10 on: August 11, 2018, 01:26:40 PM »
Thank you for the responses.  I used to carry a spare key zip tied under the side cover of my C10.  I get thousands of miles from home and worry about things like that .  I might do that with a Ford F-150 key since my 08 didn't come with a passive key, just two active FOBs.
2008 Concours
1998 R1100GS
Re: Gas Cap Key
« Reply #11 on: August 11, 2018, 02:04:53 PM »
I know I'm going to be guilty of --->  :deadhorse: :deadhorse: :deadhorse:
..but because there is so much confusion and mis-information around, I will take this opportunity to once again point out what most of you already know....
..that is that both of those active FOBs are passive FOBs as well....I know I know..you already know this..but down the road someone that doesn't will stumble across this thread
about keys and go "HUH? I didn't know that."  So this is a just a in case post.
Offline SmokinRZ
Re: Gas Cap Key
« Reply #12 on: August 11, 2018, 05:15:43 PM »
I was just thinking that storing an active FOB on your bike might not be a good idea  ;D.  Even if theft was not an issue I'm not sure if it was built with the long term elements in mind.
2008 Concours
1998 R1100GS
Re: Gas Cap Key
« Reply #13 on: August 11, 2018, 05:29:06 PM »
I leave mine in the tank bag.
Re: Gas Cap Key
« Reply #14 on: August 11, 2018, 11:53:36 PM »
Understood, and I like your idea and agree with your thoughts. The way you worded it however, might confuse a newb so I was just bangin' on a horse so we don't inadvertently become a part of the
mis-information cycle.
Offline SmokinRZ
Re: Gas Cap Key
« Reply #15 on: August 28, 2018, 05:44:16 PM »
Update:
I took the stove key and FOB in and the locksmith at first said he didn't have the blank and that I would have to get it from Kawasaki and he would cut it.  I explained that there were no specific blanks for this application and just wanted a gas cap key.  He was bale to use the FOB key to cut me an extra key that works like a champ.
Then I explained about wanting a spare passive FOB made from a Ford blank.  He tested my FOB and said he could do it but it was going to be $80, so I held off that.  Is that the going rate for a smart key?
2008 Concours
1998 R1100GS
Re: Gas Cap Key
« Reply #16 on: August 28, 2018, 06:27:41 PM »
That seems a bit high to me, based on my poor memory of what others have said they paid.  $50 seems more reasonable...
http://www.zggtr.org/index.php?topic=18252.msg248160#msg248160
http://www.zggtr.org/index.php?topic=18252.msg258040#msg258040
You can buy a genuine Kawasaki passive fob for around $35 online, but then you have to bring it and the bike to a dealer and pay $$$$ to have it added to the ECU.  So you do have to factor the TOTAL cost of the key.  $80 is actually not crazy when you figure a dealer is likely to charge something like $35 or more for the special-order fob + another $50 to program it + you still have to go somewhere to have the physical key cut, which is another $10 or something.
The active fob- well, that is a LOT more.
Re: Gas Cap Key
« Reply #17 on: August 30, 2018, 03:33:48 PM »
Smokin' is not correct again, in his statement you can't get key blanks... should have asked before posting a fallacy.. sorry.
I just went thru this for someone wanting a new stove knob cut, so here, all the keys, and differences, and KAW p/n's for replacement blanks below, and attached picture...
27008   27008-0048   KEY-LOCK,BLANK,#A
27008A   27008-0049   KEY-LOCK,BLANK,#B
27008B   27008-0050   KEY-LOCK,BLANK,#A,MAIN SWITCH
27008C   27008-0051   KEY-LOCK,BLANK,#B,MAIN SWITCH
27008D   27008-0062   KEY-LOCK,BLANK,#A,SPARE FOB
27008E   27008-0063   KEY-LOCK,BLANK,#B,SPARE FOB
Offline SmokinRZ
Re: Gas Cap Key
« Reply #18 on: September 05, 2018, 10:26:07 PM »
I stand corrected, I have an 08 that came with two active FOBS and the two mini keys contained in them.  I didn't think about later models that come with a passive FOB.
My real point was, the locksmith was ready to send me on my way before I could convince him there was an aftermarket blank that would work.
Thanks for providing the part numbers MOB, it's good to know the FOB key blanks are available.
2008 Concours
1998 R1100GS
Offline Cuda
Re: Gas Cap Key
« Reply #19 on: October 01, 2018, 08:49:26 PM »
Gee I've been using the ignition all these years,  what's the problem :o
Gods waiting room Naples
2011 Atomic  Silver
