Author Topic: Neggy Phone Mount  (Read 1915 times)
Offline neggy
Neggy Phone Mount
« on: July 09, 2018, 07:33:32 PM »
I got a RAM ball with a 1/4 -20 threaded hole, removed the plastic cover and drilled in the center of the mark left by the ejector pin when they were injection molding the part.
1/4- 20 X 3/4 screw, lock washer, AN Flat washer to spread the load under the cover, small extension on the ball, X cradle to hold the phone
Re: Neggy Phone Mount
« Reply #1 on: July 10, 2018, 05:35:08 AM »
Typically you want a solid mount to something metal like the handlebars, risers, or center of the steering column.  I am not sure I would recommend doing what you did because that plastic cover is going to see a lot of stress with a weight on a lever like that.  Don't be surprised if it cracks, eventually.
http://www.zggtr.org/index.php?topic=19824
http://www.zggtr.org/index.php?topic=21036
http://www.zggtr.org/index.php?topic=2431
http://www.telferizer.com/products/
https://www.gpscity.com/ram-mount-motorcycle-fork-stem-base-with-1-inch-ball
https://www.rammount.com/activity/motorcycle-bases#gastank
etc
« Reply #2 on: July 10, 2018, 10:48:33 AM »
While I agree that some of the other choices suggested maybe stouter, I think your mount will be fine where it is. If it gets damaged it will probably
happen in the garage or setting a helmet on it when parked or something like that. I have a radar detector mounted on the right side plastic top cover
and I worried that it was going to fatigue and crack. However after 3 years (maybe longer) and over 30,000+ miles there is no sign of it, and mine is
out in the breeze not nestled behind the windscreen. Mine is on a diamond shaped base and maybe yours should be too, time will tell, but a painted
black (not glossy, use flat or hammered paint) SS fender washer on top wouldn't hurt your install any, after all you are going to be occasionally poking at the
screen with a gloved finger right?.
HOWEVER (this is where fm  does his :deadhorse: thingie from his soapbox) In my opinion it is mounted too low for safety. Unless you have an upper percentile spot
in the range of top 10% of self discipline, you are going to someday have your head down and locked on that phone for some reason and miss something important
going on out in front of you. I'd move it higher when you can, where your peripheral vision can assist you in avoiding an accident. Until then I hope your in that top 10% I mentioned. :thumbs:
« Last Edit: July 10, 2018, 11:27:26 AM by fartymarty »
Offline SVonhof
  • 2009 C14
« Reply #3 on: July 11, 2018, 01:35:24 PM »
It would help if you added a fender washer on top of the plastic as well as below. Otherwise, you still get a high stress point where your mount meets the top of the plastic.
Scott
