Author Topic: Why does the little cover over the front brake area keep braking ?it  (Read 2968 times)
Offline katata1100
I have replaced three times. It breaks around where the screw area is. On the fourth one, I put a thin
rubber washer on both sides of it, used thread locker and made a point to not over tighten. It broke again, after three weeks.
You might need to be more specific...
 :popcorn:
Me too..
Offline katata1100
At the grip area, in front of front brake lever pivot, is a little plastic cover secured by one screw.It sort of creeps over the on/off shut off switch.
Offline bowtie39
That protects the grip heater wiring.  You must have had that grip off lately and done something to put it in a bind when the throttle is opened.
Ohhh, we don't have that on Gen 1's.
Ohhh, we don't have that on the superior Gen 1's.
fify
Ohhh, we don't have that on the older, lesser-features Gen 1's.
fify
Fixed it for you better :)
Re: Why does the little cover over the front brake area keep braking ?it
« Reply #10 on: May 30, 2018, 06:56:54 AM »
Twits.
« Reply #11 on: May 30, 2018, 09:12:34 AM »
Well now that we know roughly what you're talking about (sorta kinda) what do you mean by "creeps over" is yours moving? I've looked mine over and it has the one screw you mentioned in the front and then there is a lip that is at the rear (relative to the bike, not the rider's view when riding) that fits over a screw on top. I can only guess that it's not seating properly and is getting stressed either from improper mounting or fatigue from vibration also from something gone wrong. Perhaps you could show us photos from the side that we could compare to ours?
---------------------------------------------------------- thus ends the on topic portion of this post.
What's this "we" stuff.  You don't ride yours anymore.
Twits.
Black pots 'n' kettles me thinks.
Offline Eupher
  • U.S. Army, Retired
« Reply #12 on: May 30, 2018, 09:15:34 AM »
I took that cover off about a week ago to lube the throttle cable. Put it back on, and haven't had any trouble with it.
I remember having a little bit of trouble lining up the screw with the hole - but got it done with the aid of a flashlight. Are you sure the threads aren't stripped?
2012 C14 Arabian Candy Red
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
« Reply #13 on: May 30, 2018, 09:33:30 AM »
True, but I am a wealth of knowledge and sarcasm concerning said machine. ;)   Well, maybe not knowledge but the sarcasm is there, don't you know?
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #14 on: May 30, 2018, 09:40:55 AM »
In spades.  ;) ;)
« Reply #15 on: May 30, 2018, 01:43:20 PM »
katata1100, as far as I know your the first to have problems with that cover breaking.
Sounds like something is not aligned properly.
Where is it breaking?
Knowing that should help you figure out what is in a bind.
« Last Edit: May 30, 2018, 04:07:56 PM by connie_rider »
Offline zarticus
1986 Honda V65 Magna - Black
1984 Honda V65 Magna - Black
