Author Topic: I guess I need to have this fixed  (Read 3838 times)
Offline SVonhof
  • 2009 C14
« on: May 16, 2018, 05:45:09 PM »
I noticed this while putting the bike in the garage after my ride home from work today:
Right shock is obviously leaking at the seal. Bummer. I washed the bike about 6 weeks ago (only ridden it maybe 12 times since then) and cleaned that real good, so it is fresh.
Scott
Offline jwh20
Re: I guess I need to have this fixed
« Reply #2 on: May 17, 2018, 05:26:58 AM »
Before you spend a lot of time or money replacing the seals, try Seal Mate:
http://sealmate.net/
They've never failed to work for me.
Offline bob h
« Reply #3 on: May 17, 2018, 05:44:42 AM »
+1!!!
Worth a try; inexpensive, and it's worked for me several times!
« Reply #4 on: May 17, 2018, 07:48:13 AM »
Every bike I have ever owned with inverted forks does this occasionally and most of the time using something like Sealmate tool (in the past I've used a piece of 35mm film) fixes the problem easy peasy.
Offline SVonhof
  • 2009 C14
« Reply #5 on: May 17, 2018, 07:58:51 AM »
Sealmate on order! Should be here Saturday and I should be able to get to it on Sunday or Monday.
Thanks for the info! Looks like a great, inexpensive fix!
Scott
« Reply #6 on: May 17, 2018, 08:34:26 AM »
I'm going to get one too and throw in the toolbox for when I need it.
In my dirt biking days I can't imagine how many fork seals I changed.
Wonder how many $$ I would have saved by having one of these...
Offline Tree
« Reply #7 on: May 17, 2018, 02:35:39 PM »
A thin, flexible, sturdy piece of plastic is all you really need.  Cut up a plastic milk jug and soften/round the edges and go to town.  Insert it far enough to penetrate the width of the seal and go around the tube.  Bounce the front end a few times and repeat once or twice more.
Of course, I found out about this stupid-easy fix after I paid for a complete seal replacement.  8)
Offline Poseidon
« Reply #8 on: May 17, 2018, 05:08:37 PM »
Plastic 2 liter coke bottle works also for those lactose intolerant fork seals out there. lol
2017 Concours 14
2016 Victory Magnum
2013 M109R
Offline 2talltim
  • 2008 C14
« Reply #9 on: May 18, 2018, 07:12:45 AM »
He has a 09 I would think it's seal replacement time if they haven't been done already. Esspecially if the fluid/oil hasn't been changed regularly. Seal mates are great in a pinch or on the road but it's usually not a long term fix unless its just fluke. But what do I know?  :loco:
Offline PH14
« Reply #10 on: May 18, 2018, 10:41:21 AM »
I don't know, my 2009's forks don't leak.  :popcorn:
Offline SVonhof
  • 2009 C14
« Reply #11 on: May 20, 2018, 04:50:53 PM »
Got the SealMate on Friday and today I had time to work on it. So far so good. The hose clips were a pain and I got the two rear ones off without breaking or cutting them, but the forward one (right side) there is no way to get in there even with the long needle-nose plyers I have, so I cut it.
I will report back after a few rides (didn't feel like riding it other than around the block today).
I also mounted the light mounting brackets from n3nman on the other forum mounted. Need to get some good hook-up wire and shorter bolts before I can mount the lights onto them, but they went on easy.
Scott
Offline jwh20
« Reply #12 on: May 20, 2018, 07:10:58 PM »
You might need 2 or 3 "treatments" with the SealMates in some cases.  So don't give up after one try if the leak continues.
Offline SVonhof
  • 2009 C14
« Reply #13 on: May 21, 2018, 12:32:07 PM »
Got it, thanks!
Scott
Offline SVonhof
  • 2009 C14
« Reply #14 on: May 29, 2018, 06:55:33 PM »
FYI, so far so good. Rode to and from work today which included some good compression of the forks several times and the tubes were nice and clean when I got home.
Scott
« Reply #15 on: May 29, 2018, 08:03:49 PM »
Yep, it really works.  I was amazed.
