Author Topic: What is the actual weight of the center stand on an '08 C14  (Read 1125 times)
Offline teqnc2
Now that I've added a bunch of farkles to my '08 C14, it weighs more than the stock weight.
I'd like to get back towards the stock weight. I'm wondering whether removing the center stand will make much of a difference?
Offline Rubber_Snake
  • 2009 GTR1400 ABS, Black
Re: What is the actual weight of the center stand on an '08 C14
« Reply #1 on: May 05, 2018, 06:29:09 PM »
The center stand is probably around 7-10 pounds, but I wouldn’t ever take mine off.  It’s too useful for doing routine maintenance, cleaning, and repairs.  As long as you haven’t added a bunch of weight a long ways from the center of gravity, it shouldn’t affect you too much.
Hey, you could always reflash the ecu and get that power to weight ratio back.   ;)
« Reply #2 on: May 05, 2018, 06:44:16 PM »
If you've dumped the stock exhaust I doubt the farkles you've added will overcome the weight savings.
