Author Topic: MRA X-Creen Touring Windshield   (Read 5244 times)
Offline KawaC14
« on: May 04, 2018, 11:00:30 AM »
Anyone rocking the MRA X-Creen Touring Windshield ? I was thinking about trying one. Any input is much appreciated.
Being politically correct, isn't politically correct.
Offline Gscott
Re: MRA X-Creen Touring Windshield
« Reply #1 on: May 05, 2018, 05:02:03 AM »
I have the short version of it with Madstad  brackets, what you want to know?
Offline KawaC14
« Reply #2 on: May 05, 2018, 06:38:35 AM »
Does it perform as advertised and do ya like it? 8)
Offline Justcliff
« Reply #3 on: May 05, 2018, 07:01:56 AM »
I have had a MRA Vario for several years now. Works great even being smaller than the stock 08 shield. Lots of smooth clean air. Added the Madstad brackets last year & was amazed at how well they worked. Very quiet & lots of air. I did remove remove the brackets for winter, simply because of the amount of air flow.
Simply put, the MRA Vario & Madstad brackets are a outstanding combo!
Cliff
2008 C14, 290,000 miles & counting!  2014 V-Strom 1000 - 2010 C14
IBA#66047
Offline KawaC14
« Reply #4 on: May 05, 2018, 08:08:35 AM »
Sounds good. When up, the back pressure on the stock screen kills me on long rides. I have had bugs actually smashed on the inside of it. I do a few IBA rides every year and I'm in the saddle up to 20 hours a shot. Thanks.
Offline Justcliff
« Reply #5 on: May 06, 2018, 05:50:19 AM »
Back pressure is nonexistent.
Cliff
IBA#66047
Offline Gscott
« Reply #6 on: May 06, 2018, 06:09:09 AM »
Agree with Justcliff smooth air hits me just below the shoulders, have been playing with different angles. On center stand top all the way forward roughly 60 degrees raising the screen from fully down a LOT of forward push not good. Reduced angle to 53 degrees raised screen up about 2 inches wind noise decreases wind still hits me shoulder level, with wife on back raise the screen a little more she says wind noise decreases for her as well, no backpressure, smooth airflow , seems like airflow is from underneath the screen. Went out yesterday set screen at 48 degrees by myself not really any difference from 53 degrees. Bike is an 09.
« Reply #7 on: May 06, 2018, 07:27:26 PM »
I like the MRA X-Creen windshield extension:
http://www.zggtr.org/index.php?topic=16222.0
Offline KawaC14
« Reply #8 on: June 26, 2018, 01:19:21 PM »
Well,  installed my new Xcreen and wow. What an improvement over the oem windshield. Works great, the high back pressure gone. I can adjust the various vent positionsand it looks great. I'm really happy with it. Thanks for for feedback.
« Reply #9 on: June 26, 2018, 03:34:48 PM »
I am amazed at how much additional flexibility and control I get with that little MRA X-screen extension thing.  Takes quite a while to figure out what all the positions do and at what speed and with which base windscreen (the standard or cut-down) and with what base screen height is selected.  But it is worth the learning.
« Reply #10 on: June 26, 2018, 03:40:37 PM »
FIFY  :-)
I am amazed at how much additional flexibility and control I get with that little MRA X-screen extension thing.  Takes quite a while to figure out what all the positions do and at what speed (Easy Boys!) and with which base windscreen (the standard or cut-down) and with what base screen height is selected.  But it is worth the learning.
« Reply #11 on: June 26, 2018, 03:56:51 PM »
Offline Snype
« Reply #12 on: July 03, 2018, 03:38:12 PM »
I always thought that back-pressure was intended.  When I ride in the rain, the  back-pressure sucks the water off of my visor.  I had a BMW that didn't have that pressure and I found it almost impossible to ride in the rain.
Snype
« Reply #13 on: July 03, 2018, 03:57:37 PM »
Generally, back-pressure is not desired for any purpose (in this context).  If I understand correctly, it is an indication that airflow is not optimal- some of it is curling back behind the rider and pushing forward, rather than flowing smoothly around, behind, and away.  It is a type of turbulence that is not only annoying to the rider, but also destroys aerodynamics (leading to poorer performance, poor mileage, buffeting, fatigue, and limiting top speed).
« Reply #14 on: July 03, 2018, 05:42:01 PM »
(EZgirls) One mans' motorcyclist's blowing is another mans' sucking I guess. I always thought it was the wind blowing on my visor that cleared off the rain.
Offline PH14
« Reply #15 on: July 04, 2018, 12:01:43 PM »
Agreed. I found the back pressure with the stock 2009 windshield to be very fatiguing. It went away with the CalSci windshield. Back pressure is definitely something you do not want on a motorcycle.
« Reply #16 on: July 04, 2018, 12:51:37 PM »
The only time I have back pressure is when the regular windscreen is all the way down (stock 2nd gen).  And it can be pretty severe- my jacket actually squeezes me... the sucker is glued to my back and pressing me forward.  Interestingly, if I raise it just an inch, poof, the pressure is gone and the jacket relaxes.  Raising the screen a little seems to let just enough air in under the screen to change everything for some reason.  I don't understand how, but I am just glad it works.
I don't have the problem at all in the summer, because I switch to the cut-down windscreen and there is just air all over.
Offline KawaC14
« Reply #17 on: July 06, 2018, 08:47:44 PM »
Offline KawaC14
« Reply #18 on: July 06, 2018, 08:51:48 PM »
That's funny  8)
