Author Topic: ABS Electronic bits  (Read 2276 times)
Offline Tree
ABS Electronic bits
« on: March 31, 2018, 06:00:47 PM »
The question I would like to pose to the "Collective" is:
Can the electronics be removed from the ABS hydraulic pump for a 2008?
If so, I would like to know if anyone has tried and succeeded.  Even better, if it is possible to replace the electronics, where can I get my hands on a used assembly?
Anyone who has seen my other posts knows exactly why I am asking.   ::)
Offline Freddy
Re: ABS Electronic bits
« Reply #1 on: March 31, 2018, 06:05:30 PM »
You must have missed this in the midst of your misery.
http://www.zggtr.org/index.php?topic=21700.0
There seems to be a supply of suitable units in UK going cheap.
« Last Edit: March 31, 2018, 08:50:00 PM by Freddy »
Offline Tree
« Reply #2 on: March 31, 2018, 10:28:03 PM »
I read that post last year... before I had my Plasma Ball encounter.  I guess it was in the back of my mind but I couldn't recall what the outcome was.  I will post in the Wanted section to see if anyone has an '08/'09 ABS ECU wiring assembly.
Thanks for the reply.
Offline Freddy
« Reply #3 on: April 01, 2018, 04:31:45 AM »
Isn't it the ABS ECU you're after - that black plastic part of the ABS unit?  The ECU comes as part of the complete unit.
Offline Tree
« Reply #4 on: April 01, 2018, 01:56:44 PM »
I am looking to replace the ECU associated with the ABS hydraulic pump.  I may be assuming something here since I thought I read that the connector and ECU can be removed from the body of the unit and re-connected to another one.  Thereby replacing the electronics.  That's what I'm hoping to achieve.
Offline Freddy
« Reply #5 on: April 16, 2018, 06:40:36 AM »
Tree, how did you resolve this?  As per sportytoes in the linked thread above?  Just curious.
Offline Tree
« Reply #6 on: April 17, 2018, 10:50:36 PM »
I placed this issue on the back burner.  I'm still noodling out why my fuel level indication/warning isn't quite right.  It may end up that I will have to remove the gas tank to replace or test some things so that would be when I look into replacing the ABS pump - or at least the electronic portion.  I'm still not clear if the electronics can be replaced on the hydraulic pump or if I have to replace the whole thing.
Offline Freddy
« Reply #7 on: April 18, 2018, 02:27:17 AM »
Understood.  Sportytoes reported that he successfully swapped the ABS ECU (electronic bit) to solve his problem.  His admonition was - DO NOT remove the pump unit from the valve body, only the ECU from the opposite side of the valve body.
Offline Tree
« Reply #8 on: April 18, 2018, 10:37:42 AM »
I do recall reading that the electronics were successfully swapped as reported in a prior post - without having to remove the ABS pump.  I have feelers out to see if anyone has a seized pump from which I could cannibalize the electronics.
Without being repetitive does anyone out there have a seized pump from which I could cannibalize the electronics?  Turn your junk into a couple of bucks.
Thanks for the followup Freddy. :)
« Last Edit: April 18, 2018, 11:31:45 AM by Tree »
« Reply #9 on: April 18, 2018, 12:19:58 PM »
You might reach out to    Steve in Sunny Fla    http://www.zggtr.org/index.php?action=profile;u=387
Offline Freddy
« Reply #10 on: April 18, 2018, 04:14:08 PM »
MOB also has one.
Offline Tree
« Reply #11 on: April 18, 2018, 05:41:11 PM »
I PM'd Steve.  I can't find MOB.
« Reply #12 on: April 18, 2018, 05:42:48 PM »
Offline Tree
