« Reply #2 on: March 22, 2018, 02:58:00 PM »
Simple:
Low: Do you need low because your legs are not long enough or not? If not, then do not get low because it is harder. If you need low, then get low because it is lower.
Pod: Will you ever ride with a passenger? If so, then don't get the pod. If not, then get the pod because it is great storage and looks neat.
Heated: Do you ride in cold weather and does your butt get cold? If so, get heated. If not, don't.
Logged
