Author Topic: Switchback lighting real cheap  (Read 4497 times)
Offline Mhodges
« on: August 13, 2017, 06:15:28 AM »
Hello everyone! Been lurking for awhile and this is my first post. Found switchback lighting on EBay for the cheap.
http://www.ebay.com/itm/2x1156-BAU15S-2835-42-LED-30W-Car-Dual-Color-Switchback-DRL-TurnSignal-Light-USA-/172802474943
I installed this yesterday and so far it works great. Nice and bright. And you can't beat the price: $22 shipped!
Re: Switchback lighting real cheap
« Reply #1 on: August 13, 2017, 07:15:27 AM »
Surprised by both the price and that they have the strange "Y" type offset required by our bulbs.  I still prefer my solution of yellow front running lights at full brightness and then blinking off for turn signals (and with a solid-state flasher/no load resistors), but it was a lot of work.  That solution (the switchback) is much easier.  Had it been available back when I did all the work on mine, I would have jumped on it for sure.  For a motorcycle, it is a major safety feature to have always on more/wider lighting on the front and front sides creating the coveted visible "triangle" to front facing vehicles and a marker for side vehicles.  The stock placement of the front turn signals on the Concours makes them ideal for yellow or white DRL.
It would be cool to see development of something similar for the clear rears- dim red for tail lighting, bright red (or 3 flash + solid, with delay-to-reactivate) for brake, and yellow with switchback for turn.
Welcome
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #2 on: August 13, 2017, 07:19:13 AM »
Welcome to the forum, Mhodges!!!
Offline Scaffolder
« Reply #3 on: August 13, 2017, 03:00:18 PM »
Are these the ones from Mod My Gauges, or a different company?
Joel from Maine.
Offline mikeyw64
  • Country: wales
« Reply #4 on: August 13, 2017, 03:08:13 PM »
They look like the same ones I bought from fleabay which required a bit of self modification but are significantly cheaper than the preconfigured option
http://www.zggtr.org/index.php?topic=22172.msg274910#msg274910
Offline Mhodges
« Reply #5 on: August 13, 2017, 03:58:53 PM »
These are plug and play mostly. Just connect 12v to the loose wire for running light. And mount / zip the resistors. I had to push rubber grommet all the way in to secure light bulb and done. Worked perfectly first try.
Offline Speedie95
« Reply #6 on: August 15, 2017, 12:13:56 PM »
I installed the same ones recently, only I got them for $12.45 from Ali Express. I already had the 2 pin LED Flasher Relay installed, so I went ahead and cut out the resistors and wired them directly into the existing circuit. Tapped the accessory wiring on the left side of the bike ('08 model) for the switched power and voila. Excellent and cheap mod.
Offline Rubber_Snake
  • 2009 GTR1400 ABS, Black
« Reply #7 on: August 27, 2017, 01:00:15 PM »
Mhodges,
Could you post a pic/vid of the finished product?  I'm curious to see how it looks.
Thanks,
Ray
Offline mikeyw64
  • Country: wales
« Reply #8 on: August 27, 2017, 01:33:34 PM »
Mhodges,
Thanks,
Ray
This is mine of the same thing
! No longer available
« Reply #9 on: August 27, 2017, 04:36:52 PM »
This is a video I found on YouTube of the install.  Seems pretty straightforward.  I am going to install the DMP flasher relay and cut out the resistors, since I plan on installing some JDM Astar bulbs on the back.
https://youtu.be/4L_WKmHIHfE
Offline ljcorby
  • COG#: 9359
« Reply #10 on: August 28, 2017, 02:52:32 PM »
Mhodges,
Thanks,
Ray
Has anyone purchased and installed the ones from ebay and if so how do you like them?  I am interested in getting some.   Thoughts?
10 Kawi Concours 14 ABS
Offline mikeyw64
  • Country: wales
« Reply #11 on: August 28, 2017, 03:02:07 PM »
pretty much the ones I've got. Full write up in my Youtube video up there although some peeps have managed to put them in without the bodge I resorted too a
Offline Mhodges
« Reply #12 on: August 28, 2017, 11:47:37 PM »
I've been trying to post a video but it won't let me for some reason
Offline Mhodges
« Reply #14 on: September 15, 2017, 09:33:46 AM »
MHodges,
Thanks for the write-up.  I bought the same set up, took forever to ship from China, and installed it yesterday.  Couldn't find a clean way to stash the original sockets so I just cut them out and soldered the wires together.  Works like a charm.
