Author Topic: Phil's rack and other mods  (Read 2990 times)
Offline mturner
« on: June 04, 2017, 11:22:41 AM »
Looks like now is the time to take advantage of Phil's luggage rack with 10% off.
I just purchased one of Phil's racks, so that should qualify me to make an evaluation.  First off all, I would like to start out by saying I'm a very picky person.  Every detail is extremely important to me anytime I make anything.  I'm a gun builder and competition shooter, so attention to detail has always been important.
Now back to the luggage rack.  My first intention was to write a CNC program, and make the rack myself.  By doing this I would be assured of quality that I would approve of.  After all, if I can make it myself, why pay for someone else to do it?  Sometimes, that is the best way to look at it, and occasionally it's the wrong way.  If you do everything yourself, you never have time left to do anything else.  This was one of those times.   When Phil's rack came in, I just kept looking at all the attention to detail.  This thing is a work of art.  This is what kawasaki should be making.  This was one of those rare times (and I mean really rare) that I was really glad that I just paid someone else to get what I want.
For mods, I purchased the Givi NNT Monokey, and the E135 light kit.  The trunk goes really well with my black bike.  The light kit has some nice design to it, but not without it's problems.  The contacts that are supposed to connect when you close the lid, didn't make contact.  I had to heat and bend the bottom mount sideways about 1/16".  The next problem was the location of the knockout in the bottom of the trunk.  It was in a bad location to use Phil's rack.  I corrected that to a location that allowed me to bore a hole in Phil's rack that finished out beautifully.  My next disappointment was the fact that it was brake lights only.  I was hoping the LED lights would be dim for running lights, and bright for brake lights.  This problem was solved by putting a diode in the brake light and running light wires.  It was also required to put a resister in the running light wire to make the LED's dim until the brake was engaged.  That method works perfectly.  It is also possible to re-key the lock, and use the same key as the bike.  This can be anywhere from free, to $30, depending on the security level you need.  The free way for me was that two wafers (or tumblers) were usable.  I don't have to have the utmost in security.  All I know is that now my bike key works, but the original trunk key doesn't.  The $30 method is to buy the trunk lock from Kawasaki, and move the wafers around to match your bike key.
The other mod was a charging port.  Since I used a barrel connector, it can easily double as an accessory port.  See pictures below.
Michael
Offline philipintexas
    • Phils Farkels
Re: Phil's rack and other mods
« Reply #1 on: June 07, 2017, 01:32:50 PM »
That's a REALLY ingenious solution in relocating the socket. A lot of people have asked me how to use it and I never thought of re-location it to the center-line of the rack. Kudos.
Offline mturner
« Reply #2 on: June 07, 2017, 08:53:25 PM »
Phil,
I'm glad to see that this could help others.  I'm also glad that I could give you a well deserved thumbs up on your luggage rack.
Thanks, Michael
    • Phils Farkels
« Reply #3 on: June 08, 2017, 11:04:51 AM »
Always good to hear, especially from a machinist who appreciates the extra steps needed to make a "pretty" product.
Offline mturner
« Reply #4 on: June 09, 2017, 11:16:24 AM »
For those who haven't seen Phil's luggage rack in person, Phil put a corner radius on the top of the top of the ribs.  Not only does this add nice detail, they also are not sharp.  They won't cut into your plastic luggage.
Michael
    • Phils Farkels
« Reply #5 on: June 12, 2017, 01:57:59 PM »
Michael, how did you move the socket in the trunk bottom? That might be helpful to others. A detailed explanation might help others who want to do the same thing. Thanks.
Offline mturner
« Reply #6 on: June 12, 2017, 08:30:11 PM »
I just drilled a hole in the new location.  The size was somewhere around .875", best I remember.  On your rack, I also needed the hole to be around .875", but I finished the size off with a boring bar.  After that, I had to counterbore the underneath side of the rack, because the plastic isn't designed to fit in a 1/4" thick rack.  Before any work can easily be done to the rack, a fixture in the mill vise is drilled and tapped with the same pattern as the rack.  Only two bolts are needed to hold the rack for machining. Another trick I used was clay on the luggage rack to transfer the location of the contacts from the bottom of the trunk to the surface of the luggage rack.
Michael
