Author Topic: Eco map?  (Read 3366 times)
Offline Fontenot
Eco map?
« on: March 03, 2017, 02:50:53 PM »
I have a 2016 C14, I am thinking about a flash for power, but  I  would like to keep the eco map that  I use to cruise. Is the ECO Map still there after the flash?
2016 Black C-14
Ivan's Flash
Two Brother's pipe.
Re: Eco map?
« Reply #1 on: March 03, 2017, 03:07:59 PM »
Welcome!!
Technically, there is no such thing as an "ECO" map or mode.  It is a "FEAM" (Fuel Economy Assistance Mode) map.  When you reflash the ECU, they will not overwrite the FEAM map, just the main/normal map.  So you can switch to the FEAM (to compare, or just use normally, if you wish) with the press of a button (on gen2 C14's).
Steve will say that his current flash offerings will probably match or exceed even the FEAM map's average MPG, so really you win no matter what with his.  It has not been my experience that the Guhl flash will increase mileage, so the FEAM might retain more usefulness with that choice.
Now, I think we need at least a few more new but separate flash threads!    ::)
Offline Ron Dawg
  • a/k/a ron203
Re: Eco map?
« Reply #2 on: March 03, 2017, 07:38:22 PM »
I don't know. I had mine flashed in June of last year and haven't been interested in seeing what Eco will do. (I get 44-45 mpg).
2014 C-14 Red
Re: Eco map?
« Reply #3 on: March 03, 2017, 07:44:20 PM »
My point exactly.  With a modern reflash, the FEAM isn't very interesting anymore.
Offline Classvino
  • Longtime Kawi Rider
Re: Eco map?
« Reply #4 on: March 06, 2017, 08:37:26 AM »
Not that I can think of a real application, but can the ECO map be overwritten?  Basically, can both 'tunes' be replaced independently?
Just wondering..
Jamie
2013 C14 - First "new" bike
Re: Eco map?
« Reply #5 on: March 06, 2017, 08:48:39 AM »
Assuming you are keeping stock exhaust or perhaps just a slip on, then yes, what Max said. If your going to a full exhaust replacement and Steve's "AreaP" flash, then the "ECO" map is still there but you wouldn't want to use it. It would run way too lean.
Re: Eco map?
« Reply #6 on: March 06, 2017, 03:42:21 PM »
There is no ECO map, but there is a FEAM map (doesn't roll off the tongue very well).  Steve indicated (in another recent yet duplicate thread) that he does not have the tools to overwrite it.  I assume that it CAN be overwritten, but it would take someone with the time, tools, desire, energy, etc, to figure out how to do it.  It is a neat idea, but there [apparently] hasn't been enough demand to warrant it being done.
Re: Eco map?
« Reply #7 on: March 06, 2017, 08:24:30 PM »
You could always get a Gen 1...
Offline Steve in Sunny Fla
    • Shoodaben Engineering
Re: Eco map?
« Reply #8 on: March 07, 2017, 06:29:36 AM »
The eco map is still present and untouched, but because I have to shut off the 02 sensors to control fuel on the base power map, I expect that the eco map is similarly affected. Regardless, the pre-15 models did fine in ECO with no 02 sensors, and honestly, I built a lot of economy into my maps, and I don't think most folks even consider using eco any more once I've installed my flash. HTH, Steve
Re: Eco map?
« Reply #9 on: March 07, 2017, 04:21:27 PM »
+10
ECO Map... SCHMECO Map.. we don' need no eco slap.....
I want the map that does this, because I already get 42 mpg all the time.....
All I need is the MONSTER map, with major de cell charectristics for engine braking, and J12 booster power when going on the loud stick...
Oh, and to quote Spicoli, "a cool buzzz and some tastey waves , bro"
