Author Topic: Maybe I should Ride  (Read 8230 times)
Offline mikeyw64
  • Country: wales
Maybe I should Ride
« on: March 01, 2017, 11:44:13 AM »
like Miss Daisy more often. My normal slightly more enthusiastic commute is typically 40-42 (imperial) MPG
Re: Maybe I should Ride
« Reply #1 on: March 01, 2017, 01:36:21 PM »
Not bad.
But was that for only 34 miles?
Offline mikeyw64
  • Country: wales
« Reply #2 on: March 01, 2017, 02:43:58 PM »
Not bad.
Aye , thats my daily round trip commute, had just filled up and reset, doubt it will last lol
« Reply #3 on: March 01, 2017, 02:59:15 PM »
My average MPG is always about 42, just like the tire pressures :)
Offline mikeyw64
  • Country: wales
« Reply #4 on: March 01, 2017, 03:24:21 PM »
If thats 42mpg (US) then in real money thats 50mpg , not too shabby :)
« Reply #5 on: March 01, 2017, 03:31:50 PM »
Yes, US gallons.  42 is pretty reasonable... I wouldn't expect much more from such a large engine and large motorcycle... although some do better with a more recent/modern ECU flash than what I am using.  42 is mostly highway and some spirited acceleration (but mostly just cruising).
It can certainly go DOWN from 42 when I ride aggressively (lots of unnecessary throttle/etc), but that is pretty rare for me.
I think my G37S gets about 22MPG highway.  Both vehicles require high octane.  But at least the G37S has a 350 mile range; the C14 is only about 240 (which I think is too low for this class of motorcycle).
Offline mikeyw64
  • Country: wales
« Reply #6 on: March 01, 2017, 10:54:06 PM »
A lot depends on where you are and local traffic conditions.
Here in the UK(especially on the dail commute) the majority of my riding is point & squirt , dart & dive, in & out of traffic.
Best comparison I have is with the Birds (cbr1100xx). Typically in the UK I would be averaging around 36mpg/30mpg(US) on the daily run rising to around 43mpg/36mpg(US) if I was taking my GF out for a run.
On a 3 week 5000 mile holiday in Oz on a borrowed Bird i was regularly seeing 45mpg/38mpg(US) plus without even trying :)
That said at least the FI Bird has a 24 litre tank instead of the tiddly 22litre tank fitted to these fine machines, a bike like the GTR really deserves a much larger tank (29 litres on the ST1300, the old ST1100 was 28 litres, the FJR is around 26 litres) as even the most ham fisted rider should (if needed) be able to get 200 miles minimum to chicken light :D
a 26 litre tank with 4 litres reserve would even at my normal commuting MPG just about fulfill that requirement. 28 litres more so (as on my old ST1100 which regularly saw 200 plus and ridden gently 300 miles to chicken light)
« Reply #7 on: March 02, 2017, 04:40:02 AM »
Who the heck gives a rat's rip what fuel mileage you get?  :loco:
Geezers! ;D
Offline JerBear
« Reply #8 on: March 02, 2017, 04:48:04 AM »
Geezers! ;D
That seems like a reasonable question given it is a sport bike however, the engineers put a display of MPG on it so that must be for the TOURING half of this bike.
2008 C14 Non-ABS
« Reply #9 on: March 02, 2017, 05:49:30 AM »
I really don't care much, other than it affects my range and it is an indicator of engine health (if you ride it the same, generally the MPG should be the same)
« Reply #10 on: March 02, 2017, 06:30:31 AM »
Just giving you guys some grief. 8)
But mine is never above 35, ever. And I don't care much.  I know it could be higher, I could ride slower... Naaa! No thanks! ;D
Is it Spring yet?
http://i415.photobucket.com/albums/pp236/Jimmymac25/003_zps7f4bc42b.jpg
[imghttp://][/img]
Offline mikeyw64
  • Country: wales
« Reply #11 on: March 02, 2017, 06:37:50 AM »
Im actually more bothered how far I get between tankfuls, the MPG is fine its just that the fuel tank is 4-7 litres too small ;)
« Reply #12 on: March 02, 2017, 09:05:50 AM »
I have a 40 mile commute each way. So because of the size of the tank I am forced to fill up every other commute day. Which means I have to fill up at 160 miles, because I can't make it to 240 reliably.
Offline Classvino
  • Longtime Kawi Rider
« Reply #13 on: March 02, 2017, 11:31:52 AM »
I have an 80km (49.8 miles) one way commute to work, and I fill up every second day.  I've never run out, but have gotten the low fuel warning a couple times. On the slabs, I usually use ECO mode to try to eke out a little more time between fillups... With the dash set to metric, on "Current" display, you don't get mpg, you get km/litre (which is weird, since it's usually litres/100km) and I'm usually in the 17 - 25 range- which works out to about 40 - 49 mpg.  If I'm not in traffic, and feeling bored, I'll sometimes see how high I can get it to go - hit 31 kml a couple times (downhill with a tailwind).
Fortunately I have a tailwind most mornings, and little or no headwind in the evening. I haven't checked the non-"Current" settings in a while...
Jamie
2013 C14 - First "new" bike
« Reply #14 on: March 02, 2017, 01:50:00 PM »
Geezers! ;D
I really cared when I was riding through Nebraska, Wyoming, Utah and Nevada...
« Reply #15 on: March 02, 2017, 02:57:56 PM »
Exactly.  This bike should have had a 7 gallon tank, not 6.  Oh well!
« Reply #16 on: March 02, 2017, 03:01:07 PM »
Yeah, an aux. fuel tank is really the only cure for that.
Not sure how your fuel stations work in the UK but here in the northeast of the US. finding fuel is no problem, day or night, or even on holidays. That changes in the western part of the US where there can be 50 or more miles between gas stations on the highway (motorway). This is exactly why I conjured up the low fuel warning indicator eliminator..... to use the WHOLE fuel tank when riding in the northwestern US through the night when station are few, far apart and a lot of them close.
« Reply #17 on: March 02, 2017, 03:10:11 PM »
Yeah well, you know that is all really one big state, right?
Like Wyomintannadoho in the north west.......
I believe it is something like 840 miles (statue miles) from northern Scotland to the southern tip of the UK, the longest distance that can be traveled in the UK in a straight line. The distance on I-90, entering South Dakota from I-29, to the Pacific is about 2 1/2 forever's. Fuel was a big concern and I always made the trip with aux. fuel, although most times it was in a separate container. Still, the thought of running out of fuel at 3:00 AM is a bit scary in Wyoming, Montana or Idaho is a bit unnerving 'cause 1) they only have one street light between them and it was not working when I went through and 2) they have really big bears. Sure, you can shoot them but that just whets their appetites and attracts them to the muzzle flash....
Offline mikeyw64
  • Country: wales
« Reply #18 on: March 02, 2017, 03:40:18 PM »
With very few exceptions (like the far north of scotland) you're never very far from a fuel station in the UK, its just a PITA .
Europe is pretty much the same, just have to watch out for the unmanned automated stations that only "like " certain bank cards, which is why I always carry two there plus cash
« Reply #19 on: March 02, 2017, 03:43:52 PM »
I have an '09, what's ECO mode?  ;D
