Author Topic: Heated gear on the acc fuse?  (Read 3580 times)
Offline kzz1king
« on: February 23, 2017, 10:20:32 AM »
Anyone running just a jacket on the acc 5 amp?
Wayne
2010 CONCOURS
1974 Z-1
Re: Heated gear on the acc fuse?
« Reply #1 on: February 23, 2017, 10:26:26 AM »
You can change it to a ten. The 08's are 10 amp... Yes, I've done it.
« Reply #2 on: February 23, 2017, 01:34:16 PM »
 :yikes:   Right.   And that nuclear explosion in the background of your avatar is what happened when you did it.
Offline kzz1king
« Reply #3 on: February 23, 2017, 03:55:23 PM »
Tried what? The fuse change, heated gear on that fuse or both? Thanks
quote author=jimmymac link=topic=22213.msg275281#msg275281 date=1487870786]
[/quote]
2010 CONCOURS
1974 Z-1
« Reply #4 on: February 23, 2017, 04:25:53 PM »
I do not think the acc. circuit will carry a heated jacket, at least not the Gerbing I have; the jacket liner I use is 77 watts and draws about 6 amps. And if it did work, you would be right on the edge of the circuit limit and any small surge would open the fuse. My opinion would be to run a dedicated line back to the battery, fuse it at 15 amps, and you can also then use that aux. power tap to charge the battery, and even run an electric air compressor in addition to your heated gear.
Wayne
Offline mikeyw64
  • Country: wales
« Reply #5 on: February 24, 2017, 02:28:06 AM »
Charge the battery, what is this odd thing of which you speak? Just ride the bike all year round lol
BTW I would do it that way but use the acc feed to trigger a relay so the aux feed is ignition on only
« Reply #6 on: February 24, 2017, 04:05:13 AM »
To answer your question kzz1king, what jimmymac was suggesting was to change out the 5A fuse for a 10A fuse in your C14's ACC Circuit.
Go the route that B.D.F. suggested would be my suggestion, but with a 30A fuse, because some air compressors may even blow a 15A fuse.
« Reply #7 on: February 24, 2017, 04:33:33 AM »
That's what I've done without any issue.  The heated gear runs directly from the battery.  However, using the accessory circuit to power a relay sounds good as well and there's no chance of leaving it on to drain the battery.  And by leaving it on, I mean leaving the heat controller pulsing without it connected to the heated gear.  It would eventually drain the battery down like that.  I haven't done that yet and don't plan to, but I'm getting older and more forgetful.
« Reply #8 on: February 24, 2017, 05:22:35 AM »
I do ride the bike year- round. Note the white stuff on the ground in my avatar. :-)
Switching on an aux. circuit with the bike's ignition is a mixed bag and a judgement call. My bike is wired for 60 amps auxiliary (30 amps directly to the battery, 30 amps from the alternator feed, done this way to get around the 30 amp main fuse) but those circuits are always hot and not dependent on the ignition being on; this is really handy when trying to charge a weak or dead battery because if wired through the bike's 'ON' circuit, one cannot close the relay to begin the charging cycle in the first place. Plus my GPSs are wired in those circuits and I do not want them to shut off when I switch the bike off when, for example, getting fuel. And finally, I have never left the bike and still had any of my heated gear powered up.... it would take a really long tie- in cable to walk very far from the bike and still be plugged in.
Offline mikeyw64
  • Country: wales
« Reply #9 on: February 24, 2017, 05:39:09 AM »
See I'm odd, I like having my GPS shut down (& power up) automatically with the ignition and given that the TomTom400 is pretty much instant on (it sleeps rather than full off) it's not an issue (or I can hit the cancel button and keep the screen on).
Offline kzz1king
« Reply #10 on: February 24, 2017, 08:59:27 AM »
I ended up just plugging a fused line into the existing battery tender line. Routed the excess into the tank seam so it is unobtrusive but easy to get at. I dont use the tender once riding season starts anyhow. Thanks all.
Wayne
2010 CONCOURS
1974 Z-1
« Reply #11 on: February 24, 2017, 10:23:31 AM »
Great.
That is sort of what I was suggesting- an all purpose, aux. electrical connection that can be used for multiple things. Your battery tender connection IS that outside aux. connector and is already on the bike, though I did not know you had one of those already. :-)
Wayne
« Reply #12 on: February 24, 2017, 10:26:46 AM »
At first I read that as "See I'm old....." and then I realized you typed "odd". Well, I am old AND odd and I like my GPSs to stay powered up 'cause sometimes I am in a hurry and do not want to / can not wait for GPSs to power back up. :-)
http://www.zggtr.org/index.php?topic=1441.0
« Reply #13 on: February 24, 2017, 09:17:35 PM »
My Zumo takes just about FOREVER to boot and actually start playing music.
