Author Topic: Fork Springs  (Read 6449 times)
Offline 2talltim
  • 2008 C14
Fork Springs
« on: February 05, 2017, 09:22:14 AM »
Does anyone make a heavier fork spring than the 1.2kg/mm stockers? Im about to service my forks and thought since im in there i'd do some upgrades. Racetech recommends 1.4kg/mm springs for a rider my weight but does not sell them. Anyone know of any out there?
Re: Fork Springs
« Reply #1 on: February 05, 2017, 12:05:33 PM »
Might be easier to lose some weight..
Re: Fork Springs
« Reply #2 on: February 05, 2017, 12:33:42 PM »
Try Traxxion.... http://www.traxxion.com/
Offline zarticus
Re: Fork Springs
« Reply #3 on: February 05, 2017, 05:14:59 PM »
:nuts:
1986 Honda V65 Magna - Black
1984 Honda V65 Magna - Black
Offline 2talltim
  • 2008 C14
Re: Fork Springs
« Reply #4 on: February 06, 2017, 10:31:51 AM »
I've actually have already lost 65 lbs in the last 11 months. But currently I'm still 240lbs with gear on.
Offline zarticus
Re: Fork Springs
« Reply #5 on: February 06, 2017, 10:53:50 AM »
Ignore the insult, It was uncalled for  :thumbdown
Re: Fork Springs
« Reply #6 on: February 06, 2017, 11:45:07 AM »
I took it as an attempt at humor.
Re: Fork Springs
« Reply #7 on: February 06, 2017, 01:30:46 PM »
It was.  I'm in the same boat.
I find humor, sarcasm, and cynicism in everything.   Whether called or not called for and will continue to do so.
Offline 2talltim
  • 2008 C14
Re: Fork Springs
« Reply #8 on: February 06, 2017, 01:45:07 PM »
No insult taken I actually tried to post another comment and crack a joke back but the site kept crashing on me earlier.
Re: Fork Springs
« Reply #9 on: February 06, 2017, 01:58:19 PM »
I looked at the traxxion site and found the springs but how the heck do you figure out which one you need?
Offline 2talltim
  • 2008 C14
Re: Fork Springs
« Reply #10 on: February 06, 2017, 02:01:26 PM »
There is a spring rate calculator on the racetech page. I'd post a link but I'm on my phone right now and I'm pretty sure it requires a flash player.
Offline 2talltim
  • 2008 C14
Re: Fork Springs
« Reply #11 on: February 06, 2017, 02:02:41 PM »
Here is the link .. but like I said it probably won't work on a phone
http://racetech.com/ChooseVehicle.aspx
Re: Fork Springs
« Reply #12 on: February 06, 2017, 02:13:11 PM »
If it was me, I'd call Traxxion and ask.  ::)
Re: Fork Springs
« Reply #13 on: February 06, 2017, 02:14:48 PM »
Yeah, I'm familiar with that.  Here's what came up:
1.367kg/mm  Then they give you all kinds of options but not a spring per se..
Have you changed your fork fluid lately? Ok, I see you're getting ready to do that.  I've found that dirty fluid makes the suspension harsher.  It did with mine.  Course if you want it harsher then you could use the next weight up oil or play with the levels.
What symptoms are you having with the bike that makes you think the suspension needs to be beefed up?
Where are the adjustments set on the front?
BTW, systems are back up and nominal.  Insult away...  If it goes down again when you try to insult me....what can I say....the system is in self preservation mode.
Re: Fork Springs
« Reply #14 on: February 06, 2017, 02:15:27 PM »
That's too fricken easy, Gary.
Offline 2talltim
  • 2008 C14
Re: Fork Springs
« Reply #15 on: February 06, 2017, 02:22:55 PM »
I just know I have her cracked down as tight as she will go and I keep a zip tie on my fork tube and they still bottom out. Being a 2008 and still have the original fluid in there I'm definitely going to change that out but while I have it apart I just want to do anything I can that will improve the handling instead of having to do it again later. So I'm just looking at what my options are. Not necessarily dissatisfied with the way handles but just curious if it could be better.
Re: Fork Springs
« Reply #16 on: February 06, 2017, 02:29:15 PM »
It can always be better.  I think that GPINK has a good idea (much as I hate to admit it) about calling Traxxion and talking to them before you do anything.  May be worth it to have them R&R your forks.  I'm not bottoming out (easy boys) on mine....yet.
Re: Fork Springs
« Reply #17 on: February 06, 2017, 02:45:36 PM »
Soooo, is that another attempt at humor?
Re: Fork Springs
« Reply #18 on: February 06, 2017, 02:51:02 PM »
 :rotflmao: Possibly.  Of course it could be an insult.  One never knows around here.  You could always report me to me if you want.
Re: Fork Springs
« Reply #19 on: February 06, 2017, 03:08:45 PM »
 ;D Report to moderator Done
