Author Topic: 2nd air solenoid problem  (Read 2760 times)
Offline JhVenezuela
  • Country: ve
« on: January 21, 2017, 07:08:23 AM »
Hi,
after replaced the head cover gasket, the bike display F1 Error.
The KDS display a 2nd Air Solenoid problem
But i don't know exactly, where is it.  (i could not find at the manual with that name)
Tha bike start without problem, every connections look Ok.
Any idea ?
Appreciate your help.
Re: 2nd air solenoid problem
« Reply #1 on: January 21, 2017, 07:19:58 AM »
Did you get an error number?  Only thing I can find is 64 Air Switching Valve (The air switching valve controls the flow of the secondary air by opening and shutting the solenoid valve.)  I'll see what else I can find on it.
Ok, looks like it's on the right side.  You have to remove the middle fairing.  Looks like its just to the left (as you look at it) of the right side air intake and down a bit.  Hopefully someone will chime in on photos as its going to be tonight before I can get to it.
Offline JhVenezuela
  • Country: ve
« Reply #2 on: January 21, 2017, 07:46:12 AM »
The KDS don't show any number, just the message.
I'm going to check it again.
« Reply #3 on: January 21, 2017, 08:18:11 AM »
I don't know if this is it or not, but I copied all the troubleshooting stuff out of my manual..
Offline JhVenezuela
  • Country: ve
« Reply #4 on: January 21, 2017, 12:38:45 PM »
The Air Switching valve connection was loose.
But the KDS called it "2nd air solenoid"
« Reply #5 on: January 21, 2017, 02:53:28 PM »
Yep, terminology can be important.  It is irritating when names don't match.  I run into it all the time both in the physical world and non-physical (software) world.
« Reply #6 on: January 21, 2017, 03:52:26 PM »
Glad you got it sorted.
