Author Topic: wont start - fuel bars flashing!  (Read 2764 times)
« on: December 16, 2016, 10:49:37 AM »
Keypass operating, cranking healthily but will not fire. Just finished reinstalling my battery and also had my tank off, running some acc. wires under tank.
When I hit the start button, engine cranks and the fuel gauge bars flash and go up and down. I have never seen this before, anybody ?
Going out to raise tank and look for problem. Any ideas welcomed.
Re: wont start - fuel bars flashing!
« Reply #1 on: December 16, 2016, 11:24:24 AM »
If it was fine before you worked on it....you done something to it.  Go back and check everything again.
« Reply #2 on: December 16, 2016, 12:34:03 PM »
I did, the fuel range mod had come disconnected. All is well now!
« Reply #3 on: December 16, 2016, 12:49:48 PM »
Too bad I did not see this earlier.
Yep, when you disconnect the fuel pump harness and turn the ignition on, what you get is the top three bars and then the bottom three bars of the fuel gauge flash on and off in turn. That is how the ECU tells you it cannot sense the fuel pump out there. The other thing that goes along with this is that you will not hear the fuel pump run when you turn on the ignition (it runs for three seconds before shutting off) but most people are not really paying much attention to that, and you cannot hear it with a helmet or helmet and hearing protection anyway.... at least I cannot.
BTW- nothing to do with the L.F.W.E., the bike will do the same thing with my harness in place or not. In fact, that is one of the tests I do to all of my circuits before sending them out (though not in the bike, I do it on the bench).
« Reply #4 on: December 16, 2016, 12:58:38 PM »
Excellent!
« Reply #5 on: December 16, 2016, 04:01:47 PM »
It is pretty loud- I can and do hear and notice it every time I turn on the ignition, even with helmet and hearing protection.  And I am usually sitting on bike so I can feel it, too.  I always wait until the pump is done before trying to start the bike.  Not sure if that is required or expected or if it even matters, it just seems like the right thing to do.
« Reply #6 on: December 16, 2016, 05:00:36 PM »
When I saw the wacko behavior of the fuel bars I figured it was trying to tell me something, either that or I had fried the sucker. I had managed to mangle the clip that holds the diabolical connectors together when I installed Brian's module and it was just held together by the snug fit. Raising the tank to access the accessory wires pulled it apart.  I have it taped together now.
