Author Topic: Second Ground (Blue Connector)  (Read 1556 times)
Offline JerBear
« on: November 20, 2016, 01:34:54 PM »
The Second frame ground that you disconnect with the blue connector when removing the battery, where does it go to?  I would like to know how far it snakes back into the battery area.  I know, I know just follow the wire but It's too darn cold out there and when I put it all back together for the Spring I would like to know how big of a job it is to get to the other end of that wire to clean ALL of the ground connections.
2008 C14 Non-ABS
Re: Second Ground (Blue Connector)
« Reply #1 on: November 21, 2016, 02:51:03 PM »
Not positive, but iirc it ran to the back of the main relay and fuse right there... been a while....
Offline JerBear
« Reply #2 on: November 21, 2016, 03:45:12 PM »
Thanks.  I'll spend more time on it when spring comes and I reinstall the battery.  I know that poor grounds can make for bad things to happen so I like to clean the contact points well at least once a year.  I was just trying to figure out of the end of the ground wire that I can't see will be in the area under the seat or the tank.  I'm thinking the tank.
2008 C14 Non-ABS
