Author Topic: Has anyone else had an issue with headlight condensation?  (Read 2602 times)
Offline PlaynInPeoria
« on: July 21, 2016, 06:13:09 AM »
https://flic.kr/p/Jp1NXs
I noticed this recently, I don't know if it's normal or a bad thing?
Re: Has anyone else had an issue with headlight condensation?
« Reply #1 on: July 21, 2016, 06:48:29 AM »
I've never seen it on mine.
« Reply #2 on: July 21, 2016, 01:41:36 PM »
Nope.... mines fine....
When you did your HID conversion did you muck up the rubber boots that seal the rear??? Only way that could happen...
Id pull the lamps, get the bike in the sun, and dry the shells out with a hairdryer completely, and install the lamps and boots paying close attention to getting them sealed...
The shiney coating on the reflectors can and does succumb to corrosion after a time, if not sealed...
« Reply #3 on: July 21, 2016, 02:55:48 PM »
Me neither, on mine.
Offline Deziner
  • Phoenix
« Reply #4 on: July 21, 2016, 07:48:41 PM »
Dude! I've seen that before. I think your high beam fluid is leaking inside of your housing.
Offline angelo
    • Some Ride Reports
« Reply #5 on: July 21, 2016, 08:27:22 PM »
Just started happening to mine this past week in the ozarks.  Haven't changed a bulb- got the bike last summer and have been in rain before.  Was assuming the seals along the edge leaked.  08 30k miles btw.
Offline EZ
« Reply #7 on: July 22, 2016, 08:45:14 AM »
My 2012 just hit 46k.  I had HID issues on my trip out west (ballast failed on right side) and I removed the boot to swap in a new built to try the easy fix first.  Didn't fix it but I have washed it recently , maybe I didn't get the boot sealed properly.  I will attempt MOB's solution and report back.
« Reply #8 on: July 30, 2016, 03:06:03 PM »
I pulled tell rubber covers and let it air out, seems fine now.
« Reply #9 on: July 30, 2016, 03:11:20 PM »
Whatever you do, don't let the smoke out of the electrical system!
