Author Topic: What do you like for a wheel balancer ?  (Read 6661 times)
Offline kzz1king
« on: June 02, 2016, 07:09:41 PM »
Well after changing tires for years with spoons and balancing them on there axles leveled across a homemade stand I have decided to upgrade. I bought the HF changer and made some blocks for it. SailorChic talked me into a MoJo lever so maybe I should upgrade my balancing too.  So what do we have, I like inexpensive.
Wayne
2010 CONCOURS
1974 Z-1
Offline DaddyFlip
Re: What do you like for a wheel balancer ?
« Reply #1 on: June 02, 2016, 09:23:58 PM »
http://www.marcparnes.com/Kawasaki_Motorcycle_Wheel_Balancer.htm
Don't mess around; get this. I use two cinder blocks for stands.
2001 ZR-7s "Ol' Red"
1995 FXDWG
Offline PlaynInPeoria
« Reply #2 on: June 02, 2016, 09:29:29 PM »
My friend whose house I change tires at has this, so did another.  Good stuff and he's a great guy.   I also have his Visual Alert for turning the output of a headphone jack of a radar detector into brightly flashing LEDs.
« Reply #3 on: June 03, 2016, 06:52:46 AM »
+3 on Marc Parnes including the balancer and the visual alert. Top notch quality and service.
« Reply #4 on: June 03, 2016, 10:59:43 AM »
+4
I'm thinking that this must be the kind of "piling on" that V'Jim can tolerate?
..anyway..Another advantage of the Marc Parnes balancer is that it is so low friction, that I can get the wheel really spinning fast on the balancer out in the garage
and then go in and brew a cup o jo and then go back out and check to see if the battery replacement on the TPMS was effective (registers on the dash display)
 before I go to the trouble of balancing a wheel that I might need to take apart again to fix my soldering job on the new battery.
« Reply #5 on: June 03, 2016, 01:50:33 PM »
+4
DUH moment! Why didn't I think of that? I tried spinning the TPMS in a sling. Didn't work. Should have used my balancer.
« Reply #6 on: June 03, 2016, 03:14:03 PM »
Swinging a C-14 tire pressure sensor from a string absolutely does and will work- I have done it at least 10 times, all with different sensors. And if you wear a pin striped suit and chew gum while doing it, you look really cool like a 1930's gangster. And if you do it at a 'tech. day', you will hit at least two people with the sensor every-time you test one, no matter how loudly you yell 'stand back, I am swinging a sensor in a circle'.
On the tire balancer- I like and use the one from Harbor Freight. Four bearings, very sensitive, robust axle and cones (not plastic!) and it does not need anything else to be used such as cement blocks, etc. I have used one that had plastic cones that I did not care for at all as the cones were distorted from use and the threads for the locking screw were stripped out; I do not remember the brand but I would suggest staying away from any type with plastic cones.
« Reply #7 on: June 03, 2016, 03:38:29 PM »
I never could get the string thing to work. How long do you have to swing that thing (easy boys)? And just FYI the cones from Mark Parnes are precision made aluminum. I agree I wouldn't want plastic.
Offline kzz1king
« Reply #8 on: June 03, 2016, 03:41:06 PM »
The harbor freight  will go well with all the other red in the garage. :D
[/quote]
2010 CONCOURS
1974 Z-1
« Reply #9 on: June 03, 2016, 04:47:39 PM »
the h/f balancer comes in basic black.... 8) not red....
I agree with Brian, I have nothing bad to say about the h/f balancer, even though some folks had "issues".....
I will say, for the cost savings, it works.... so, maybe you may have to pull the bearings off, spray them down with wd40 to completely clean them, and then lube them with light oil, or even vasoline... and all is nice... and if someone is unlucky and damages the rod... omg..... pick up a hardened drill rod from mcmaster carr... if necessary....
I did however grind the rod ends tapered so the end is "pointy", this makes it so if the rod touches the frame, for some reason, it doesn't effect rotation.
for all the bally hoo'd precision, and cost over the Parnes tool, I just have to laugh about the monster sized thumbscrews... yeh, that balances well... and the fact you set $100+ tool on 2 cement blocks to use it.... precision at its finast..... bwaaahaaahaaaaaaaa... whatever...
h/f rocks....
Offline DaddyFlip
« Reply #10 on: June 03, 2016, 06:49:12 PM »
On what do you set your pointy HF balancer? A rainbow?
1995 FXDWG
Offline zarticus
« Reply #11 on: June 03, 2016, 09:00:33 PM »
The harbor freight has a built in stand, Can be used on your workbench or floor. The other one needs to be put on blocks or jack stands
1986 Honda V65 Magna - Black
1984 Honda V65 Magna - Black
Offline DaddyFlip
« Reply #12 on: June 03, 2016, 10:57:38 PM »
Which also, incidentally, can be used on your workbench or floor.
1995 FXDWG
« Reply #13 on: June 04, 2016, 12:07:15 AM »
h/f rocks....
Well I've never used anything other than Marc Parnes balancer so I can't, and haven't, said anything bad about the HF balancer.
I hope nobody thought my post was putting down another type of balancer. My garage is full of HF stuff, unless there's a fire in which case it was
all Snap-on stuff, and 2 of each.
As close to the axle as the "monster sized" thumb screws are I doubt they have much effect, but just to be sure I set them opposite (180 degrees) each other.
I do use the MP balancer atop HF jack stands.  ;)
I do believe the No-Mar balancer has plastic cones available and some prices that make the MP stuff look thrifty.
Offline kzz1king
« Reply #14 on: June 04, 2016, 06:40:29 AM »
Right or wrong I have been balancing my bike tires on there own axles forever and seem to have gotten good results.I have thought of doing a DIY one that lets the axle also rotate on skateboard bearings but HF sounds easier. Thanks for the input all.
Wayne
2010 CONCOURS
1974 Z-1
Offline DaddyFlip
« Reply #15 on: June 04, 2016, 07:02:28 AM »
Wayne
As long as they balance to your satisfaction, you are a winner.
1995 FXDWG
« Reply #16 on: June 04, 2016, 01:08:53 PM »
I set it on the heavy steel top of my Delta table saw, which is perfectly level.....
and I don't have to bend over and work /grovel on the floor......
cement blocks are too much money for me, I need em to hold up all the non runniƱ abandoned cars and trucks in mah frunt yard....
I spose I could use one u the old refrigerators I gots out back, hmmmmm ... I always leave the doors on em, the kids like to play hide n seek in em...
