Author Topic: Modular helmet - chin guard  (Read 4070 times)
Offline Awaz
« on: June 28, 2011, 10:16:23 AM »
Do you know if the chin guard can be completely removed to make it a 3/4th helmet, and put it back on when in need? Just investigating possibilities. Helmet in question is a Gmax 54s.
2016 Ducati Scrambler
2008 C14
Re: Modular helmet - chin guard
« Reply #1 on: June 28, 2011, 12:54:23 PM »
Not sure about the GMax, but the Scorpion EXO 900 has this options. I think a few others do also (Shark maybe).
Offline Awaz
« Reply #2 on: June 28, 2011, 03:19:21 PM »
I see two phillip type plastic screws that holds the Chin bar. It appears to pivot on those when lifted up and down. But before I try to unscrew them, thought I ask here first.
2008 C14
« Reply #3 on: June 28, 2011, 06:18:10 PM »
I see two phillip type plastic screws that holds the Chin bar. It appears to pivot on those when lifted up and down. But before I try to unscrew them, thought I ask here first.[/quote
Aw ca'mon. Screw first ask questions later. ;)
Offline MrFurious
« Reply #4 on: June 28, 2011, 09:38:20 PM »
I just purchased a Shark Evoline 2 ST about a week ago specifically for it's convertibility.  I looked at the Shark and the Scorpion EXO-900, but chose the Shark for two reasons.  First, you can ride at any speed with the chin bar up/open without getting the air-dam effect that you get with any other modular on the market.  Second, you don't need to remove/add parts on the Shark to go from full-face modular to 3/4 open face - Just flup the chin bar back and snap it in the rear lock position and away you go.  However, I will not that you don't want to try going from open face to closed while moving as the detent locking the chin bar in the rear position is a good one and it takes some effort to pop it loose to rotate it forward.
Shark Evoline 2 ST Helmet Review at RevZilla.com
Jim B.
COG #9642
2009 C14 - Black - Non-ABS
Insanity is not as easy as I make it look!
Offline Awaz
« Reply #5 on: June 29, 2011, 09:07:25 AM »
 :rotflmao: maybe that is what I will have to do!
2008 C14
Offline Bagger
« Reply #6 on: June 29, 2011, 07:47:10 PM »
Nolan N43 Trilogy Motorrad Helmet has a chin guard that detaches easily.  Face shield with only full up or full down, chen vent.
I have one coming in to try.  Not a true Modular as in the 103, but close.
Check out some helmet web sites to take a look, or go to Nolan's home page.  EZ to find.
