Author Topic: Tying down a C14  (Read 9485 times)
Offline OPUS
Tying down a C14
« on: June 27, 2011, 09:29:23 AM »
I know this has been addressed at sometime on old forum but I can't find anything.  What is the best way to strap down this beast without scratching or breaking something.  I know there are some products out there.  Any opinions?
Offline tyler1015
Re: Tying down a C14
« Reply #1 on: June 27, 2011, 09:32:04 AM »
I go through the lower triple tree. Just loop it over that on each side and it stays away from the fairing real well. U might need to buy strap extenders to do it. I have a nice set of straps that have a loop already on it. U can get extenders for like 5 dollars at walmart.
Offline JetJock
« Reply #2 on: June 27, 2011, 10:20:07 AM »
Canyon Dancer and tie-downs.
« Reply #3 on: June 27, 2011, 10:40:07 AM »
It just doesn't get any easier.
Offline TRBN
« Reply #4 on: June 27, 2011, 11:23:41 AM »
Don't Canyon Dancers use the handlebars as the tie down point?  I have seen pictures of the this being a HUGE no-no!  Broken handlebars pillars due to tie down forces on the handlebars....
Aaron
Offline tthompsr
  • 2009 Black Concours
« Reply #5 on: June 27, 2011, 11:34:28 AM »
The Aluminun handlebars on this bike are not sturdy enough to hold down this Bike!
I would and do use the triple tree with extenders on the straps.
Offline lt1
  • 2008 C14
« Reply #6 on: June 27, 2011, 11:34:54 AM »
We have had at least one forum member (2 IIRC) that wound up with broken handlebars as a result of using Canyon Dancers.  I have them and like them, but no longer would use them on my C14.  Of course, I don't think my C14 has been on a trailer yet.
I would also recommend sticking to the lower triple tree for the front tie-down.
Eyes, Brain, Hands.  Repeat.
Offline okxd45
« Reply #7 on: June 27, 2011, 01:50:20 PM »
Me too as we will hopefully be moving from OK to PA this September.  Mine will be strapped to a cycleshell if that makes any difference.
Jeff
Offline okxd45
« Reply #8 on: June 27, 2011, 01:54:52 PM »
How about the back?
Jeff
Offline JetJock
« Reply #9 on: June 27, 2011, 02:15:03 PM »
You base your opinion on what exactly? That they're aluminum? In other words, like about 75% of all bikes out there and probably 90% of dirt bikes?
If the handlebars aren't strong enough to support the bike with the forks partially compressed to be trailered, then they're not capable of controlling the bike when it's being ridden.
« Reply #10 on: June 27, 2011, 02:25:30 PM »
People have been saying the Canyon Dancers stress the handlebars since I've been coming to this forum because someone snapped the handlebars.
I can destroy/bend/break the handlebars or clipons of any bike with canyon dancers if i put more pressure on the bike than it can possible take.  I can also trash the forks/seals and maybe even pop the tires with canyon dancers. I never tried the "what breaks first, the handlebars or forks over-compression" trick.
I'll keep using canyon dancers till the end of time, safest way for any of my bikes
Offline Freddy
« Reply #11 on: June 27, 2011, 05:16:25 PM »
I tie the front wheel into a cradle on a 6x4 box trailer then tie only the rear of the bike down using 2 straps each side to compress the rear suspension, with no straps on the front suspension - and no problems at all.
Offline tthompsr
« Reply #12 on: June 27, 2011, 06:08:54 PM »
This is what my opinion is based on, I broke this bar.These are not designed for the downward force unlike a dirt bike which has a cross brace.
Offline JetJock
« Reply #13 on: June 27, 2011, 06:23:17 PM »
Interesting, but I'm not convinced. I have hauled a lot of bikes around with Canyon Dancers, including the Concours on one occasion, never a problem. You can bend/break anything with enough effort . . . or simply bad luck.
Offline reesedp
  • Sail Army
« Reply #14 on: June 27, 2011, 06:53:58 PM »
I just went through this in preparation for a TDY trip (ended up they made me fly...)  Remove the cover under the front of the fairing.  Use 18" extender straps around the tree on each side.  i put two in the middle extending straight out (the Army sailor in me securing cargo...)  The two on the back slightly compressing the shock.  Took it out for a spin and she didnt move an inch.  Would easily have made the 1600 mile round trip.
Offline CrashGordon
« Reply #15 on: June 27, 2011, 08:46:09 PM »
I've used a Canyon Dancer with the Concours with no problems. I strap down the front and rear with all straps pulling down and forward into a wheel chock. I think a lot of people have a tendency to over tighten the straps when tying down the bike. You shouldn't compress the suspension more than about half way. Unless you have a really expensive trailer, it probably doesn't have suspension and you'll need the bikes suspension to keep from jarring the bike every time you hit a bump.
Offline ljcorby
  • COG#: 9359
« Reply #16 on: June 28, 2011, 12:31:25 PM »
+1, that's how I do it as well in an enclosed trailer.  Works great.
10 Kawi Concours 14 ABS
Offline S.Ga.Rider
« Reply #17 on: June 28, 2011, 07:10:20 PM »
Im interested in this too. In 2 weeks I will be loading it on the amtrack auto train and was wandering how they were going to strap it down.
« Reply #18 on: June 29, 2011, 12:10:05 AM »
Thats most of us  :D
Offline koval68
« Reply #19 on: June 29, 2011, 12:50:21 PM »
Lower triple tree is the only safe place to secure the front.....IMHO.
- Mahatma Gandhi
