Author Topic: For those of you with SMH10s  (Read 2198 times)
« on: December 25, 2015, 11:53:33 AM »
If your battery gives up, I think you can contact Sena directly for a replacement and I'd work with them before I take the route below but it's worth knowing.
http://youtu.be/4UUX99Uzn7Y
Offline overthehill
Re: For those of you with SMH10s
« Reply #1 on: December 25, 2015, 06:41:06 PM »
I actually completed that process, although most likely not as cleanly.  I took the battery to Batteries Plus and they found a replacement.  Works great.
1987 Connie gone
2003 Goldwing (yikes, no lean angle) gone
1999 Connie gone
2008 Connie
« Reply #2 on: December 25, 2015, 08:10:15 PM »
Replacing the battery will be very easy.  FINDING a suitable battery is the difficult part, since Sena refuses to sell them to anyone.  Have the exact same problem with my LG Nexus 5.
Offline Daytona_Mike
« Reply #3 on: December 26, 2015, 08:04:19 AM »
those are the same Li-pos i use in toy helicopters.  You can find those in a lot of places and you dont need 720m\amps. many times those claims are not  all true.
 650 will be fine.
Here is one
http://tinyurl.com/zmksar8
« Last Edit: December 26, 2015, 09:11:57 AM by Daytona_Mike »
