Author Topic: 2012 C14 Won't Turn Over  (Read 7590 times)
Offline Eupher
  • U.S. Army, Retired
« on: December 10, 2015, 03:38:28 PM »
I've got 600 miles on this bike. I'm sure it's got the original battery in it and while it hasn't been cold, I have noticed a bit of a wheeze in the early morning.
Today, at noon in 66 deg temps, I've got my trusty key fob, turn the key, all the bells and whistles light up, I hear the fuel pump pressurize and...
...nuthin'.
Not even so much as a grunt.
I checked the engine kill switch. It's in the run position. I flipped it back and forth to make sure "run" meant "run".
I checked and put the bike in neutral (it had been in first gear). Clutch in (even in neutral), still no dice.
Fuel is about half a tank and is only about a week old.
I'm thinking the battery has enough oomph to turn on the Christmas tree lights, but not enough to energize the coils for spark.
What say all of you masters of the wrench?
2012 C14 Arabian Candy Red
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
Re: 2012 C14 Won't Turn Over
« Reply #1 on: December 10, 2015, 03:48:07 PM »
Replace the battery.
« Reply #2 on: December 10, 2015, 03:49:22 PM »
batt may be fine, but the connections to it, and to the frame need to be removed, abrasively (sandpaper) cleaned, greased, and reinstalled tight.
most common issue with this bike is a resistive batt connection.
Offline Eupher
« Reply #3 on: December 10, 2015, 04:06:18 PM »
Thanks, gentlemen!
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
« Reply #4 on: December 10, 2015, 04:22:38 PM »
Yep, tighten all connections to the battery and frame ground and then charge up the battery.  If it still acts that way, time for a new battery!
« Reply #5 on: December 10, 2015, 04:52:38 PM »
Yeah, yeah, yeah.....what he said.
« Reply #6 on: December 10, 2015, 05:00:51 PM »
REMOVE AND CLEAN THE CONNECTIONS then install and tighten.
simply tightening a dirty connection, with invisible resistive coating, will not remedy the issue, you have to scrape off the invisible oxide coatings.
Offline Rixtrix
« Reply #7 on: December 10, 2015, 05:38:36 PM »
+1 on that. Bought my 2011 used and shortly after had the same scenario as you so ordered a new battery. When installing the new battery found that the ground to the frame was only finger tight-after tightening all was good but since I had already put the acid in the new battery I installed it. The old one is on a trickle charger as a back-up.
Offline Rixtrix
« Reply #8 on: December 10, 2015, 05:39:09 PM »
« Reply #9 on: December 10, 2015, 06:42:57 PM »
Yeah, yeah, yeah....what he said.
« Reply #10 on: December 11, 2015, 04:56:59 AM »
After you turn the ignition on (but before trying to start) cycle the display to battery voltage, keep an eye on it whilst you engage the starter.
Offline SilverConnieRider
« Reply #11 on: December 11, 2015, 08:09:32 AM »
IF and that's a big IF - the above advise doesn't solve your problem, look at the Kick Stand switch and the Tip-Over switch.
IF those are fine then I would take apart the emergency stop switch just to make sure it's fine too.  IF no-go (I know a lot of ifs') then have the
battery load tested OR just get a new one.
Good luck and let us know when you get it started.
Just out of curiosity - You said YOU have 600 miles on the bike - How many miles total are on the bike?
Offline Eupher
« Reply #12 on: December 11, 2015, 11:04:51 AM »
Good point. I'll do that. Thanks.
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
Offline Eupher
« Reply #13 on: December 11, 2015, 11:10:25 AM »
600 miles total - I bought the bike 6 weeks ago with 1 mile on the odometer. (Yeah, I know, not a lot of riding so far -- I'm workin' on it!)
I've ordered a new battery because from the get-go, I suspected that it was a battery issue. It had been wheezing a bit and as the bike literally sat in a stealership for 3 years waiting for me to come along and buy it, the battery languished as well. Batteries - most of 'em anyway - don't last as long as they once did. And yeah, when I lived in colder climes, I took the battery out and put it on a trickle charger over the winter. Even still, I could get only 4, maybe 5 years out of a battery before it went belly up.
The new battery that's on the way seems to be a bit beefier with 220 CCA. Those that I looked at (short of getting into $150-250 range, which is waaaaaay too much for me to spend on a battery) went 200 to 220. I paid $67 at batterystuff.com. Just waiting on Mr. Postman now....
In the meantime when I can find an hour spare time (I get home from work when it's dark and I don't have a garage), I'll take the old battery out and clean out the terminals as previously suggested. My Dad taught me that kinda stuff years ago anyway, but it doesn't hurt to hear it again.
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
« Reply #14 on: December 11, 2015, 11:59:46 AM »
Dealerships are notorious for not properly tightening the battery connections when assembling the bike. A 5 minute fix. Just saying...
Offline Eupher
« Reply #15 on: December 11, 2015, 02:20:28 PM »
I hear you, but this time things appear to be shipshape (apart from a semi-dead battery, of course).
During lunch I attempted to start the bike (no dice) while observing the voltage on the display. 12.1 volts DC. Apparently not enough oomph when the usual reading is 14.4 VDC.
So I pulled the battery out and the connections all were tight and looked clean. There was a bit of a pinch on the ground wire, but not enough to break the insulation. I'll clean all that up with some emery cloth and coat with some grease during reassembly with the new battery when it comes in. I'm fairly confident things will return to normal at that time and I can begin to enjoy that saddle I bought from Speedracersworld.
http://www.zggtr.org/index.php?topic=20305.msg251231#msg251231
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
« Reply #16 on: December 11, 2015, 03:09:17 PM »
You don't say which year bike it is in your signature or avatar.  [UPDATE:  DUUUUUH, it is in the subject]  If you bought an old-stock bike that had been sitting for perhaps YEARS and the battery never charged, that can and will destroy a lead-acid battery (it can sulfate when left discharged and then have no depth to it anymore).  This happened to the battery on my generator, and once I was able to shock it back to to life (lots of effort) and the next time I could not resurrect it (and the procedure is dangerous and not recommended, anyway).  Some chargers have a magic "sulfated" mode that can supposedly, eventually reverse some sulfation, but I am skeptical.
No.  The "usual" reading on the display would be with the bike running, and that usual realing is the voltage of the alternator feeding the battery, not just the battery.  The alternator SHOULD be 14.x V, while the battery should be 12.x V.  If your battery were in the 14 V range, that would be very bad (or it was just showing a fake surface charge with no load).  Also, reading the voltage of a LA battery with zero load on it is notoriously inaccurate for predicting much about the state of the battery or its charge.  Better to have at least a 1A load on it for a minute or so first/during.
Probably!
Offline Eupher
« Reply #17 on: December 11, 2015, 03:14:50 PM »
You don't say which year bike it is in your signature or avatar.  If you bought an old-stock bike that had been sitting for perhaps YEARS and the battery never charged, that can and will destroy a lead-acid battery (it can sulfate when left discharged and then have no depth to it anymore).  This happened to the battery on my generator, and once I was able to shock it back to to life (lots of effort) and the next time I could not resurrect it (and the procedure is dangerous and not recommended, anyway).  Some chargers have a magic "sulfated" mode that can supposedly, eventually reverse some sulfation, but I am skeptical.
See the Subject line above.
Okay, understood. As stated in my first post, there was enough juice in the battery to light up the Christmas tree but not enough to turn the motor over. Just on that basis and seeing that the various connections were in good shape (not loose, or heavily corroded) and knowing that the battery is 3 years old, there ya go. Best I've ever been able to get out of a battery was 5 years, and I milked that puppy (easy boys!) every step of the way.
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
« Reply #18 on: December 11, 2015, 03:35:55 PM »
LOL!!!!!!!!  OMG.  That is *classic*!!   :rotflmao: :rotflmao: :rotflmao: :rotflmao:
Yep.... my original Concours battery died after just 3 years.  But it was allowed to go dead at least once (happened much faster than expected) and I wasn't using a battery tender (now I do).
And my G37 battery only lasted 4 years!  I don't seem to have great luck with batteries.
Offline Ghost Rider 2
« Reply #19 on: December 11, 2015, 05:25:07 PM »
  He stated that gauges shows 12+ volts not 14.4  The 14.4 would be when bike is running. And from the other stuff he said he tried. Something is telling me neutral  switch.
