Author Topic: Dyno chart  (Read 13699 times)
Offline Steve in Sunny Fla
    • Shoodaben Engineering
Dyno chart
« on: September 22, 2015, 06:48:04 AM »
   Some of y'all may know I've been working on a flash for the 14. Well here's a small, almost inconsequential part of the story... the dyno chart. Most folks get really wrapped up in the dyno chart, but remember, this only tells you about WOT power no info on the real rideability of economy. Still, folks like this stuff.
  BTW this is a DEAD STOCK 2012.
 And a special  Thank You to Rembrant, who kinda kicked me into doing this  :chugbeer:  Steve
Offline connie_rider
Re: Dyno chart
« Reply #1 on: September 22, 2015, 09:17:19 AM »
Steve, give us a little more info on these plots.
Is this; 2 bikes 1 run each, 1 bike 2 runs same flash, or,,, 1 bike 2 runs/ with and without the re-flash?
Both runs seem to be pretty smooth plots with a hiccup around 4500 and 6000 on one of the plots.
Agreed that a WOT doesn't tell us all we need.
As you already know, "Seat of the pants" is the best way to determine how it actually works.
From the reports I've read about your re-flash, you've done it right.
Congrats...
If you had unlimited funds (or your own dyno) you could set a mechanical stop in the throttle and do 1/4, 1/2, 3/4, etc throttle runs. Multiple runs (at different throttle settings) would tell you more.
Unfortunately, all of this takes massive amounts of time and money
Ride safe, Ted!
« Last Edit: September 22, 2015, 10:48:25 AM by connie_rider »
Re: Dyno chart
« Reply #2 on: September 22, 2015, 10:15:05 AM »
that's my bike, 100% stock, same dyno, runs within minutes of each other. we ran with my flash, then I returned it to stock and did several runs, then returned to my flash. These #'s are real and repeatable. If you look at the beginning of the chart you see the acceleration is almost vertical to where the torque curve becomes flat and constistent; this shows the level of instant throttle response. and remember, this is with the flies in.
Steve
Re: Dyno chart
« Reply #3 on: September 22, 2015, 10:47:42 AM »
Ok, thanx.
that's my bike, 100% stock, same dyno, runs within minutes of each other.     this is with the flies in.
Well done!
Re: Dyno chart
« Reply #4 on: September 22, 2015, 03:59:07 PM »
Interesting!  Now one would want to compare to the Ghul flash....
And yes, you are correct that WOT is useful, but only as a single metric.  I can tell a huge difference in engine response before and after the Ghul reflash in "normal" and "spirited" riding at way under 7K rpm (something not explained by a chart like this).  Rarely am I ever in WOT (and I would guess most C14 riders would be similar).
Re: Dyno chart
« Reply #5 on: September 22, 2015, 04:14:30 PM »
Bam.  Reply to self:  http://www.zggtr.org/index.php?topic=15297.msg186728#msg186728
A few select quotes of mine from that thread:
"At 3K it [torque increase after Ghul flash] is pretty impressive, jumping from about 66ft-lb to 78ft-lb.  That is 18% more,  something that will certainly be noticed by everyone.  At the higher RPMs, like 6K, a 1ft-lb improvement at 88 isn't going to be noticeable by anyone (that is only a 1.1% improvement).  At 5K it isn't much whoop either (+2 = 2.3%)"
"The Ghul reflash primarily addresses responsiveness.  The secondary butterflies are what causes the lack of responsiveness and the flash essentially "disables" those[...] It DOES increase torque across the board (especially at lower RPM)."
The data on your {Steve FL} dyno chart under 3K is a bit wonkey.  Your peak hp is considerably higher than I would have expected.
Re: Dyno chart
« Reply #6 on: September 22, 2015, 05:28:10 PM »
yup, good observations. I had Chris Jones do the dyno work - Chris built Ricky Gadsons turbo bike, he knows his stuff - he and I  discussed that. He said the problem with my flash was that it's strong down low and every time he tried to "creep up" on 3k to start the run it would overspeed the drum, and he'd have to back off the throttle. It even shows on that chart - where he hit it to early, then backed out, then hit it again. Seriously there's piles of low end that the bike didn't have in stock form, but it was hard to capture on the dyno. Steve
« Last Edit: September 22, 2015, 06:53:50 PM by Steve in Sunny Fla »
Re: Dyno chart
« Reply #7 on: September 22, 2015, 06:25:55 PM »
yup, good observations. I had Chris Jones do the dyno work - Chris built Ricky Gadsons turbo bike, he knows his stuff - he and I  discussed that. He said the problem with my flash was that it's strong down low and every time he tried to "creep up" on 3k to start the run it would overspeed the drum, and he'd have to back off the throttle. It even shows on that chart - where he hit it to early, then backed out, then hit it again. Seriously there's piles of low end that the bike didn't have, but it was hard to capture on the dyno. Steve
That's a shame, because the low end torque is probably the most interesting for regular driving, especially on this type of bike.  I am wondering how they got such a pretty dyno chart down low on the Ghul flash (well, at least on stock, after the flash there was no data below 2.8K Hmm)
Re: Dyno chart
« Reply #8 on: September 22, 2015, 06:52:35 PM »
[/quote
 i dunno, but on the comparison with Guhl, which is inevitable, I WELCOME those to compare. I have already, and also with the power commandered / areap'd bikes. There's only so much that can be gotten with tuning; I think I've gotten a pretty big chunk of it. Steve
Re: Dyno chart
« Reply #9 on: September 22, 2015, 06:55:02 PM »
Even just replicating/matching what Ghul did is a huge accomplishment (and kudos, of course).  Topping it would be pretty amazing.  Since nobody else has asked.... was this ONLY changing the 'flies mapping?
Re: Dyno chart
« Reply #10 on: September 22, 2015, 07:33:07 PM »
 I'm not interested in replicating anyone's work, that's either plagiarism, or a lazy person's lack of inspiration. This is my own work from the get-go. and it's much more comprehensive than just fly mapping. As always, I STILL say that if a person is using a dyno chart to determine "the best" tune, that person is making a mistake. steve
Re: Dyno chart
« Reply #11 on: September 22, 2015, 09:40:14 PM »
I wasn't implying a copy/reverse engineering or anything of the sort.  Just a replication of the methods and results- flashing the ECU to reprogram the 'flies and some A/F tuning to get more power and responsiveness.
Couldn't agree more.  But unfortunately, there aren't a whole lot of other objective measurement tools available (or at least not practical).  At least, not that I have seen.
Re: Dyno chart
« Reply #12 on: October 06, 2015, 06:42:36 PM »
 I guess I'm a little surprised by the lack of input on this thread, especially since there were such rousing conversations in days past regarding the relative pro's and con's of leaving fly's in or removing them.  Is it settled now that flies in is superior, or does someone want to prove otherwise?  ;D  Steve
Re: Dyno chart
« Reply #13 on: October 06, 2015, 07:15:23 PM »
It's your flash, Steve. It can be what ever you want it to be. The proof seems a bit elusive to the unwashed since your work is understandably proprietary. I can only assume my failure to understand the nuances of how closing the intake tract increases performance is due to my own ignorance. Good luck with the project.
Re: Dyno chart
« Reply #14 on: October 07, 2015, 07:43:53 AM »
Ok, I'll stir the discussion a little.  :o
But, (for my efforts) you have to answer my final question...
I've always thought the Flies in approach was the better of the 2; as my assumption is they would offer better control for low rpm flow.
I assume they fully open at WOT.
(NOTE: I agree that {at WOT} they slightly decrease airflow, but the air blockage is at a minimum.
I'll guess that removed, the increased airflow can aide the engine in producing more max HP.
But, the loss of control at lower throttle openings would decrease possible torque advantage?
Several times you've made comments about the Slip On Mufflers.
From your posts, apparently you don't like them.
Why don't you like them, and how do they work (or not work) with your flash?
{ie; what is the advantage or disadvantage? [not yes they will work or no they won't]}
Re: Dyno chart
« Reply #15 on: October 07, 2015, 08:20:53 AM »
Loss of control of what?
Re: Dyno chart
« Reply #16 on: October 07, 2015, 10:04:11 AM »
It looks like you achieved 14 more HP, which is good ... and 2 more ft-lbs of torque; I would think the torque figure would matter more, but I ain't no expert  8)
Are you happy with it? Do you feel gains? If so, then you're all set  :thumbs:
What kind of input were you looking for?
Re: Dyno chart
« Reply #17 on: October 07, 2015, 10:27:54 AM »
(They put the 2nd butterfly in the throttle body for a reason, as it wasn't an inexpensive addition).
I assumed that the Kawasaki (Supplier) added the 2nd butterfly to control flow thru the throttle body.
So, if the butterfly is removed, that control is lost.
I know Steve adjusted how that butterfly was controlled to gain some of his tune...
NOTE: I'm not an expert. Just trying to stir discussion for learnings...
Re: Dyno chart
« Reply #18 on: October 07, 2015, 11:01:25 AM »
In your opinion what was Kaw's objective in controlling the air flow with the secondary throttle plates?
Re: Dyno chart
« Reply #19 on: October 07, 2015, 12:36:07 PM »
  The bike gained more than 2 #'s Tq, more like 5# at 3500 rpm, which is very noticeable.
  IMO the flies are to nanny the lower rpm power, but they aren't the impediment to power production that most think. For starters, the flies are a larger diameter than the actual throttle plates, so given any percentage of throttle opening, the flies at the same percentage allow more flow that then actual throttle plates. What folks aren't considering is reaction time from throttle input to achieving the secondary opening. They're fast, but not like the speed of light. also, I have experimented with a lot of early fly opening; flies out, and even cutting the flies. to much opening or flies out leaves a flatness / breathy feeling that slows throttle response. Very noticable if you're a tuner and know what to look for. I actually backed off of the fly opening in my flash to achieve the snappy throttle response it has. Y'all can argue / discuss / haggle it all you want; I'm telling you factually that to much fly opening or removing the flies is NOT the best way to go.
  As far as slipons are concerned, I have no issue with them at all, but I am also a realist.  The simple fact is that a slip on with a DBkiller / baffle in it probably flows less than the stock muffler, and that kills power. I know guys put on slipons for the weight savings and the look, but be careful and know what you're doing before you drop the coin.
 JMO, Steve
