Author Topic: oil pressure warning light  (Read 5826 times)
Offline speed545
« on: May 13, 2011, 04:15:59 AM »
Hey guys,
Took the bike for a ride last sunday and twice, the oil pressure light came on and went off again. It just blink.  It happened while i was shifting up from 4th and 3th.
Oil level is ok. Running Belray semi synt
Did not happen again and i commute to work with the bike
Any clue?
Thx
08, Concours 14
Montreal Fire Dept
Re: oil pressure warning light
« Reply #1 on: May 13, 2011, 04:28:47 AM »
Hey guys,
Any clue?
Thx
Still under warranty or GTPP?
Offline speed545
« Reply #2 on: May 13, 2011, 03:04:02 PM »
No warranty or protective plan anymore
It didnt do it since thoses 2 times. I did add a bit oif oil when i got back home but it was already within the proper level
08, Concours 14
Montreal Fire Dept
« Reply #3 on: May 13, 2011, 03:26:00 PM »
Check the connection to the oil pressure sensor and make sure it's tight.  You may have to replace it, though.
Offline Bourne2Ride
« Reply #4 on: May 13, 2011, 06:34:31 PM »
was the bike close to stalling? The light may come on if so.
- Heroes
« Reply #5 on: May 13, 2011, 06:56:36 PM »
Probably just a loose connection on the oil pressure sender. But you might want to have a dealer check it out just to be sure- a flashing [low oil pressure] warning is fine but true low oil pressure has to be addressed and fixed. The oil pressure sender is located at the bottom of the engine, just above the oil pan, in the very front. You should see it with a single wire going to it; check that wire and the connection to the sender itself.
Hey guys,
Any clue?
Thx
Offline speed545
« Reply #6 on: May 13, 2011, 07:39:28 PM »
thx guys
i ll have a look at it and let you know
derry
08, Concours 14
Montreal Fire Dept
