The saturday before the site crashed. I changed the forks from my 1988s to 2004, 1998 brakes, fender and rotors, new pads. Changed the wheel to a 1991 ZR6D 17" Put on a michelin PR3 120/70 17". Installed a SOOFK Changed the oil. Changed Plugs. Set valve clearence six were tight .003. Relocated the overflow tank. Installed a fuse block on the right side of the battery box. While tightening the axle I broke the speedometer drive gear. I checked to make sure the notch was lined up but it must have moved and the stress split it in two.Today the new one came from Ron Ayers, I put the front end together. Changed the fluid in the brakes and clutch mastercylinders and bled them, the clutch was the worst. If the rain stops I'll take it out tommorow.
Jack
