Author Topic: Modified License Plate Location  (Read 7499 times)
Offline FZBear10
« on: August 03, 2015, 08:43:04 AM »
I removed the OEM rear fender to try to clean up the looks of the rear end a bit. I don't really ride in wet weather at all so I was just after a cleaner look. I bought my C14 with a lot of Farkles already installed including the Givi V46 rear truck that has a really nice bracket which I used to mount the license plate. Here is the end result. I am winging it as far as the plate light goes. If I get a fix it ticket I will deal with it then, anyhow I think it came out pretty decent looking and it only cost me $1.46 at ACE for the mounting hardware.
Offline JoeRau
Re: Modified License Plate Location
« Reply #1 on: August 03, 2015, 09:05:14 AM »
Off topic but I almost had to look twice....
My garage looks similar and so does my truck.
2012 C14.  Black
COG member 10990
« Reply #2 on: August 03, 2015, 09:14:03 AM »
Looks good! Can't imagine why you would get a fixit ticket for that.
Offline FZBear10
« Reply #3 on: August 03, 2015, 09:26:22 AM »
Technically I need the tag light but I will be a scofflaw, LOL!
« Reply #4 on: August 03, 2015, 09:39:52 AM »
Ah yes, must have a light. I've seen many a custom HD with a curved plate on the side rotated 90 degrees and no light. Compared to those guys yours looks completely OEM.
Offline FZBear10
« Reply #5 on: August 03, 2015, 10:05:02 AM »
I am hoping the LEOs think so too.
« Reply #7 on: August 03, 2015, 01:04:49 PM »
in FL if its lit and visiable 50 ft away its legit no matter what bracket you use.  man that looks nice right there!
sailor_chic
« Reply #8 on: August 03, 2015, 01:59:23 PM »
It looks nice, but I can only imagine how much more road grime your going to get on the back. I know that stock rear fender isnt much, but I think it does help keep some grime off .
Offline FZBear10
« Reply #9 on: August 03, 2015, 02:02:41 PM »
I may get those little LEDs, thanks MOB.
Thanks, I like the way it looks too.
« Reply #10 on: August 03, 2015, 05:10:23 PM »
hen I bobbed my rear fender on COGZilla C10, it was after inspection. when I brought it in the following year, the kid blew me a line of $#!+ about not having a light, and tried to sell me 2 small incandescents in a similar format for $40, and wanted another $60 for the install.... I told him to pizz up a rope, left and went to my work site, 1 mile down the road, pulled off the red lens on the tail light and drilled 5 x 1/2" diamter holes in the bottom, and slapped a piece of clear box tap over it inside... I was back there 25 minuts later, and he said he couldn't see the light on the plate.... I told him to kneal down by the plate, tossed a pair of overalls over his head and asked " can you see it now??? jerk....
I got my sticker.
I'll be sending off for those led lights now, they didn't have these back in 2006....
nice little units for the price....
« Reply #11 on: August 10, 2015, 04:04:27 AM »
may I ask what's that bracket thingy left and right, between the OEM plate and the adapter plate for the topcase? And yeap, that number plate up there looks nicer, but I wonder about the dirt in the back of the bike...
Offline FZBear10
« Reply #12 on: August 10, 2015, 10:43:17 AM »
The previous owner had those acrylic spacers made so that the Givi case and the Corbin smuggler don't rub together.
« Reply #13 on: August 10, 2015, 12:56:46 PM »
Great idea to have the smuggler and a top case work together without having to move the topcase way out back (as most seem far enough back already)...
....but...acrylic? I thought it was aluminum..I know the cases are plastic, as are the oem support rails, but I thought the main purpose of the
Givi SR410 steel support arms were to beef things up a bit (but yeah, they are also great for mounting stuff), not sure how the acrylic helps
with that unless it's just a cosmetic cover over some steel bolts and spacers to actually hold the weight?
« Reply #14 on: August 10, 2015, 01:23:46 PM »
Off the subject, but what tire is that?
« Reply #15 on: August 10, 2015, 01:33:06 PM »
Michelin Pilot Power 2CT?
Offline FZBear10
« Reply #16 on: August 10, 2015, 09:22:02 PM »
They are thru bolted and really strong the brackets have no movement at all.
They are Michelin 2CT
