Author Topic: KB fork brace - opinions?  (Read 4500 times)
Offline Eydugstr
« on: July 03, 2015, 09:21:45 AM »
What's your guys opinions of KB fork braces?  Worth the money or no?  Thinking of installing one on a '05 Connie with 36K miles.
Offline Strawboss
Re: KB fork brace - opinions?
« Reply #1 on: July 03, 2015, 11:26:30 AM »
I have an older one and like it. Sorry, I'm not one to tell you the subtle differences of preload adjustments and how I can tell the difference when there is 2 turns as opposed to 3 turns, or, how it stiffens up the front end as I really couldn't tell the difference on Ohio's frost heaved roads.  What I can tell you is the bike tracks well, it doesn't wobble around semi trucks, the tires wear well, I also have a vented windscreen, the bike is an '01 with 81,000 miles. Hope that helps.
Offline connie_rider
« Reply #2 on: July 03, 2015, 01:09:22 PM »
I feel that they do help.
If your a cruiser, it may not be as noticeable.
If you like twisties,,,, handling improves.
Certainly; it does not hurt...
Offline Eydugstr
« Reply #3 on: July 05, 2015, 12:28:50 AM »
TY for the opinions.  TY for mentioning the preload adjusters.
Offline Jim __
« Reply #4 on: July 06, 2015, 06:24:37 AM »
Just be certain to go through the shimming process when you install the brace so it does not cause the forks to bind.
http://www.zggtr.org/index.php?topic=6108.msg71751#msg71751
Offline datsaxman@hotmail.com
« Reply #5 on: August 03, 2015, 06:04:00 PM »
Mine produced a very noticeable improvement in the front end feel, responsiveness, braking, and overall feel.  I would not want to ride a C10 without a fork brace.
saxman
161.5RWHP on the dyno
Formerly Silverdammit!
Offline redzgrider
« Reply #6 on: October 21, 2015, 06:41:42 PM »
Mine was a waste of time and money, and provides significantly less protection of the fork seals to boot. Bike still wiggled around trucks or cross winds, etc. I suggest SiSF's cam gear is a much better value. Or just more gas.
