Author Topic: Back Off Wig Wag Module Issue  (Read 2308 times)
Offline mikeeitup
« on: March 27, 2015, 08:13:43 PM »
Hey guys I just finished wiring the Signal Dynamics Back Off Wig Wag up to my bike. I had the module tapped into my brake light and then the two wires going to two Chirper (knock off Whelen) TIR3's. When I hit the brakes, it's supposed to then make the TIR3's go on and off back and forth. I programmed the TIR3's to do a "steady burn" pattern as I don't want them to flash and imitate a police signal pattern (yeah I know wig wag is a cop pattern but you know what I mean). Problem I am having is the lights will not stay programmed to the "steady burn" so when I brake, they go crazy flashing. Has anybody used these or has anything with the Whelen TIR3's had this issue? What have I done wrong. I had my mechanic buddy come over and an electrician check out my work. Both are stumped because the wiring is right (as far as the three of us know).
Mike
~Mike~
~2012 Black Connie~
Re: Back Off Wig Wag Module Issue
« Reply #1 on: March 27, 2015, 10:37:58 PM »
According to the site, you want mode 2, and want to connect only the orange wire and not the red.  I don't see why it would matter which types of lights you wire to the Back Off, as long as they are simple/steady lights and under the maximum wattage.
Offline mikeeitup
« Reply #2 on: March 28, 2015, 08:02:24 PM »
I wired up mode 2. Apparently my issue is I wired non steady burners. They strobe as a main function but can be programmed not to strobe. They aren't staying programmed not to strobe so now either I scrap these lights or figure something else out. Super frustrated at these lights for not being able to "remember" their last command.
~Mike~
~2012 Black Connie~
Offline mikeb2411
« Reply #3 on: April 01, 2015, 02:21:46 PM »
Mikeeitup, did you get the lights to respond the way you want? I like the idea of adding those to my bike but want to make sure they work as expected. I have the Admore light bar (flashes 3 times when I brake) located below my license plate and the LED light bar from AST (also flashes when I brake) below my rack and right above my stock taillight. I like the idea of adding this to my taillight so all lights flash when I brake!
Mike
Ojai, CA
2016 Black Triumph Trophy SE
Offline mikeeitup
« Reply #4 on: April 01, 2015, 06:39:47 PM »
So far I am a no go. I haven't been able to find a TIR3 shaped LED light that only has a solid on or single programmed "flash". Until then I'm pretty screwed.
Mike
~Mike~
~2012 Black Connie~
