Author Topic: Changed the oil at 351 miles mark during break in.  (Read 9166 times)
Offline mriboy
« on: February 25, 2015, 11:02:59 AM »
So after reading on here about all the metal in the oil after first oil change decided to go ahead and do it  and not wait to the 500 mile mark. I was shocked how much silver was in the oil and how heavy the filter was when I turned it upside down to drain out the filter was like sliver metallic model paint coming out.  Also changed the final drive out it wasn't as bad but still pretty dirty. Thanks all for the heads up and I bet my bike will love having new blood in her. I plan on doing it again in about another 300 if the site glass gets looking that dirty again or 1k mark if its looking pretty fresh still.
Re: Changed the oil at 351 miles mark during break in.
« Reply #1 on: February 25, 2015, 01:04:46 PM »
I think I did mine at 250, then 1800, then 5000...
« Reply #2 on: February 25, 2015, 03:29:52 PM »
Did mine by the book. 600 then 7500 thereafter.
« Reply #3 on: February 25, 2015, 03:39:04 PM »
Always do mine around 600 too the first time. I figure the metal floating around helps break in the engine better. Kinda like valve lapping compound.
I don't really think that, but I do wait until 600 miles to change it.
And since we have yet another oil thread, I'll step it up a notch. I used to change it after break in every 3,000 miles, but lately I've been going 5,000. Just something for you guys to mull over while it's cold out. ;D
« Reply #4 on: February 25, 2015, 04:30:34 PM »
I have y'all's cousin, the ZX14R, and when I changed my oil the first time (at break-in, 600 mi, 900, whatever it was) I drained it into a black pan and saw no metal at all. Nothin but dark-ish colored oil. Then poured all that through a filter, still nuthin.
Makes me wonder why Kawi's would be so different  ???
« Reply #5 on: February 25, 2015, 04:37:34 PM »
Sounds like someone already used yours.  ;)
« Reply #6 on: February 25, 2015, 05:17:26 PM »
I usually change my break in oil at 50 miles after doing break in drills.
I bought the connie 500 miles from home so I had to wait until I got home.   :(
All looked good though and 30,000 miles later it still looks good.  Of course there have been several oil changes between now and then.
Offline connie14boy
« Reply #7 on: February 25, 2015, 09:41:50 PM »
I've always gone 5,000 miles in all water cooled engines, and even my air-cooled 911. Never had any engine problems whatsoever.
elp_jc
« Reply #8 on: February 25, 2015, 09:56:34 PM »
If I ride that many miles in a year (it's usually less), will do exactly the same thing. This bike has by far the most oil of any bike. In fact, it has EXACTLY the same 5-qt capacity than my 550HP GTR (which is ridiculous IMO, when most such cars have close to 10 and above). And will do its first at 600 miles; anything less is overkill IMO, and I'm a maintenance freak ;D. At only 66 miles now, I won't be able to ride for a few more months :-[. Oh well. Need to make it first, and then will worry about riding ;). Have a good one.
« Reply #9 on: February 26, 2015, 05:37:44 AM »
Just don't put 5 quarts in it after a change.  You'll over fill it.  4.7qts normally after a filter change.  5 quarts on a dry fill.
elp_jc
« Reply #10 on: February 27, 2015, 10:20:59 AM »
I never do, but great advice. Always drain oil overnight, fill 1/2-qt below capacity, fire up engine for a couple of minutes, shut it off, then adjust level to the 3/4 mark when oil is cold. On a wet-sump engine, hot or cold makes very little difference (but I allow that 1/4 margin), but cold is super consistent... especially if you always park the bike at the same spot in your garage. That's my method anyway ;D.
Offline Riverszzr
    • Lloyd's Motorcycle Performance Center
« Reply #11 on: March 06, 2015, 08:53:51 AM »
25 miles is always my first oil change number. Then again at about 600-1000, depends on what I find in the first oil change. After that standard change intervals.
attached are a couple pics from a CBR250R that I recently did, there was a ton of silvery flake in the oil and the filter, plus some black silicone strips and more.
 Certainly can't be good for those to be circulating, and certainly can't possibly hurt to change the oil "early" to remove them.
« Reply #12 on: March 06, 2015, 03:31:48 PM »
there was a ton of silvery flake in the oil and the filter, plus some black silicone strips and more.  Certainly can't be good for those to be circulating, and certainly can't possibly hurt to change the oil "early" to remove them.
Theoretically, they aren't circulating, because they are caught by the oil filter if they are light enough that they could circulate.  And if they are heavy enough to not get caught by the oil filter, then they are sitting at the bottom of the pan and won't be circulating.  I suppose the biggest risk is clogging the oil filter and the possible damage by the much smaller particles that can go through the filter.
« Reply #13 on: March 06, 2015, 05:28:26 PM »
I'm kinda amazed you guys got the filter off in the first place, and hopefully you didn't torque it to the 13 ft/lbs suggested in the FSM.... you'll regret that.
As for the silver bits, play the magnet game with them.. You'll find very little Iron there... mostly aluminum, and the Moly assembly lube used during assembly... it makes the oil silvery... bigtime...
changing prior to 600 miles ain't frugal, it's wasteful, the filter works, and the aluminum.... well it's a soft metal.
just don't switch off to synth too soon, before everything seats well, lest you have consumption issues.... until Kaw delivers bikes with synth oil, fully break it in with the oils they prescribe.
Offline Riverszzr
« Reply #14 on: March 06, 2015, 10:00:10 PM »
 Aluminum may well be a "soft" metal but so are the cam caps, rod bearings, main bearings, oil pump housing and so many other parts and pieces they pass through.
( I will see if I can scroll though some pics and post them up of numerous cam caps, oil pumps, rod bearings etc all having scores in them at extremely low mileages, not to mention how many times I have seen a "chip" of aluminum stuck to crank gears or transmission gears)
 And as far as circulating, you do realize that not all of the oil goes through the oil filter all the time, there is the bypass valve (pressure relief valve) and that is always open to some extent when the engine is running, thus how it maintains the prescribed oil pressure. Otherwise you would have; say 20 psi at idle and 100 psi at redline
 Theoretically you could get the same oil and particulate matter to bypass the filter with every pass through the pump. (unlikely but theoretically it could happen)
As far as the filter catching everything, yeah right. You do know the oe filters are only rated to 20 microns at 96%, they don't even rate them for anything smaller- but you can bet the percentage is significantly lower on smaller particulate.
I know full well the difference between assy lube and actual aluminum- pretty obvious distinction, remember I have been working on motorcycles for 33 years now.
 So you go ahead and take your chances, I will not- I have had atleast 80 brand new engines apart with under 100 miles on them and know exactly how much stuff is left in the engine from the machining and honing processes. (engines getting set up for racing, but virtually brand new off the showfloor)
I think many of these forum posts on this forum and others, is just some biased bullshit because people want things to be easy and cheap. Not actually based on facts- just like all those who claim to have never needed to adjust the valve clearances, because "they were fine" what a crock of ****
 We had this discussion before and in thousands of motorcycles that I have done valve clearance inspection on, never once have I found a motorcycle to not need numerous valve clearances adjusted..
Offline Deziner
  • Phoenix
« Reply #15 on: March 06, 2015, 10:07:23 PM »
In the grand scheme of things, oil is really cheap. After spending a couple hundred on a tire that may or may not go 10,000 miles, a $30 oil change is a bargain.
Offline Throttle 8
« Reply #16 on: March 06, 2015, 10:14:41 PM »
The way I look at it---oil is cheap; engines are expensive. I have always erred on the side of caution. It might cost me a few extra bucks; but all my motors have made great power and never burnt oil.(Maybe just lucky so far, but why chance it). I usually change at 100, 500, and 1500; then every 3000. I also have always run dino oil for the first 6000 or so before switching to synthetic.
We each have our little break in rituals, if it works for you; go for it. :chugbeer:
« Last Edit: March 07, 2015, 10:18:53 AM by Throttle 8 »
2014 C14
2000 ZX12R Ninja
« Reply #17 on: March 07, 2015, 04:35:26 AM »
We each have our little break in rituals, if it work for you; go for it. :chugbeer:
 :goodpost:   ......nuff said and keep it civil.
Offline sf bay rider
  • Humble student of the ZG1400
« Reply #18 on: March 08, 2015, 12:06:22 PM »
I will run my new 2014 to 600 miles. Then use Amsoil 10W40MCF and a Amsoil 103 filter, too.  On the 2009 Connie. The valve cover gasket needed replacing @ 21K miles. The mechanic commented on how clean the internal surfaces looked.  Whatever oil you choose, choose wisely and not cheaply. IMHO
Jack
2014 Red ZG1400CEFL
« Reply #19 on: March 09, 2015, 07:38:07 AM »
http://youtu.be/-_IlNbsILLE
