I'll use the Mobil1 10/40 then; like it better than Valvoline. And since owner's manual doesn't list final drive oil weight, is the 75/90 called in the service manual for all climates? It gets hot here in TX. Would like to know if 75/140 was mentioned, and what temperature ranges. Otherwise it'll be M1 75/90, which is available locally at PepBoys. And will check Walmart for the M1 10/40; if not, AutoZone carries it for sure. Thank you for that recommendation.
Hey, on an unrelated subject, my bike has a paltry 1 (index) finger clearance between the front wheel and the chin spoiler. Is that normal on older bikes? I ask because I don't think Motorcycle Larry's long fender extender is going to clear. Might end up with the Pyramid FendaExtenda. Or maybe ProjektD's slightly longer one. With that little gap, I think stones are mostly going to hit the chin bar, and not go above it. I might have to take the Big Bend trip without that and radiator grille, and when I'm back, I'd know for sure what needs protection
. Thx.
Finally, took the bike for a 20+ mile ride today, and it was great. I really like this bike. The more restrictive P1X insert for the TBR pipe was perfect; don't want it any louder than that. It lacks the deep growl at idle, but sounds awesome under way; it's a compromise I'm happy to take. Throttlemeister worked perfectly, and looks stock (removed the red pinstripes). The grip puppies (grab-ons) are BY FAR the best mod on all my bikes, and a bargain at $15 or so shipped. Brakes are simply phenomenal, especially in feel and power. The only slight disappointment was the pegs are in the way to touch the ground, and that's why the 2015 seat didn't make any difference. But at the same time, they provide a less aggressive riding position, so I'm fine with that. Plus I can solidly put the balls of my feet, and being careful where I stop/park, should be enough to avoid joining the 'drop' club. Also feel a little more heat near my feet that I'd like (which is likely to get much worse in the hot summer), but hope it's not too bad. I only use the bike to travel to the twisties, so shouldn't be an issue for me. All in all, so far VERY pleased with my purchase. And already like it better than all of my previous BMWs
. Enjoy the rest of your weekend.
