Author Topic: Glove compartment delete  (Read 12811 times)
Offline Cruise Missile
« on: January 04, 2015, 06:05:26 PM »
I have a 2009 Concours and just purchased the 1" Pull Back adapters. Has anyone deleted the storage compartment and replaced it with the one from a 2010 or newer ?
Re: Glove compartment delete
« Reply #1 on: January 04, 2015, 06:36:49 PM »
I reckon anything can be done, but keep in mind the body the '10 door sits in is different, and it needs KiPass stove knob to actuate the '10 lock/unlock
« Reply #2 on: January 04, 2015, 06:43:52 PM »
Yes, you can remove the 08/9 glovebox and replace it with the solid panel from the 10+. You will need to change the bracket under the box for the new panel to bolt to.
« Reply #3 on: January 04, 2015, 08:07:46 PM »
Thanks , that's what I was hoping.The lid on mine was bugger by the previous owner, that and I really want to add the 1" pull back adapters that interfere with storage compartment.
So off to the local Kawasaki dealer.
« Reply #4 on: January 04, 2015, 08:42:05 PM »
ohhh i thought the idea was to properly replace the box with a '10 govebox on the left fairing...my bad. apologies  :)
« Reply #5 on: January 05, 2015, 03:23:54 AM »
No. when you buy the Pull back kit they do warn you that it can't be used on the 08-09 models because it hits the storage compartment ( or very tiny glove storage compartment). But I bought them anyway hoping it could work.
Offline zarticus
« Reply #6 on: January 05, 2015, 04:36:02 AM »
There is a 2010 piece on ebay right now for cheap money !!!
1986 Honda V65 Magna - Black
1984 Honda V65 Magna - Black
« Reply #7 on: January 05, 2015, 02:21:48 PM »
I was looking on Ebay and didn't see one. Dang it. just ordered one from Pro-Am motors sports here in Calgary. $91.00 cdn. The trim piece is the same.
Part # if anyone is interested is 14092-0112
« Reply #8 on: January 05, 2015, 03:11:02 PM »
Delete the glove compartment, eh?  Don't think I've ever heard it phrased quite like that.  Remove it, yes.  Delete, not so much.  ;)   It's funny about that glove compartment (which really isn't large enough to store a set of good gloves) that it does come in handy for some things.  Even had requests to add it back in on the 2nd gen bikes.
« Reply #9 on: January 05, 2015, 03:17:49 PM »
Yep, I find that little useless box to the one of the most useful things on the bike. Also one of the main deterrents to trading forward to a Gen. 2; the glove box on those really IS useless, at least to me.
Different people, different levels of usefulness....
<snip>
« Reply #10 on: January 05, 2015, 03:21:54 PM »
Ear plugs, disc lock, garage door opener, receipts, small tools...
« Reply #11 on: January 05, 2015, 03:28:42 PM »
They are both pretty useless, IMHO.  But I also don't think either (gen 1 or gen 2) is larger or has a better space layout than the other.  But the gen 2 version can be accessed with a tank bag fitted (unlike the gen 1) and is locking (unlike the gen 2).  So I am not sure why you find the gen 1 version is more useful.
« Reply #12 on: January 05, 2015, 03:30:10 PM »
I put a magnetic tankbag over mine at times for those long trips of 150 miles or less..
« Reply #13 on: January 05, 2015, 03:47:02 PM »
Several reasons: 1) it is right in front of me so I can look down into it, even on the road. 2) it is shallow so the stuff I put in there is readily available and never under anything else. 3) it is big enough to hold everything that I want to put in a glovebox. 4) it is not in the way of anything and because I do not use a tankbag, nothing is ever in the way of it.
I use that thing at least three times every single time I ride; the first time to reach in and press the garage door button to close the garage. The second time to reach in and press the button to arm the house alarm system (which cannot be done until the garage door is closed). The third time for certain is to de-activate the house alarm and open the garage door on the return. In addition to that, I sometimes reach into the glove box to adjust my Starcom audio system, which I can do using the remote control.... because I have a glove box that makes it easy to access. I also use it to hold my EZ- Pass transponder where it is out of the weather, out of sight (the bike has an alarm so anyone opening the glove box will make a lot of light and noise) and works every single time I have gone through an EZ Pass checkpoint.  I put earplugs in there, both new and used (OK, now for that collective "Ewwwwwwwww"). I keep a light in there where I can easily grab it anytime, including when riding. I also keep my travel / fuel logs in there along with several pens so I can quickly and easily jot down my stops for the IBA during sanctioned rides.
I can reach into the glove box while rolling (feet up) and open the garage door. I could not do that with a Gen. 2 glove box, plus because they are deeper, some stuff would end up under other stuff and that would not work for me.
In short, I absolutely love that cheap piece of garbage on the Gen. 1 C-14's, use it all the time and have no use for a Gen. 2 glove box.
But I also put two LED's in the glovebox which illuminate it at night and that makes it about a million times more useful for me- I could not find virtually anything in there at night (which is 1/2 of the time I ride on long rides) without it being illuminated. So mine might be substantially more useful than it was stock; I know it is for me being illuminated.
« Reply #14 on: January 05, 2015, 04:41:12 PM »
Well, if you do have to upgrade to a newer model, at least it is theoretically possible to put a gen 1 tank glove box on a gen 2
http://www.zggtr.org/index.php?topic=1872.0  (unfortunately he didn't upload the photos, I will ask him)
« Reply #15 on: January 05, 2015, 05:50:17 PM »
Ahem, you mean 'update', not 'upgrade', right?  'Cause the Gen. 2 models need a lot more tweakin' than just the glove box to snuggle in-between my legs. ;D
I would not bother with putting the early glove box on a later bike, I would instead conjure up a small tank bag that mounted on an arm that could be pivoted up and away from the fuel tank. But then this all comes down to personal preferences as well as how we use our bikes; I can be in and out (Easy Boys!) of a gas station in well under 2 minutes and back to highway speeds, and that is meaningful to me. That very same thing is probably not of any use or interest whatsoever to most people who ride a C-14.
Besides all of that, my '08 is just getting broken in at 100K miles. No need to think about anything else for a while. Sure it needs a little body work on the right side, and a little body work on the left side, and a coat of paint more or less all over but hey, you know what they say..... 'Bondo in your doors shows courage in your heart.'.
« Reply #16 on: January 06, 2015, 06:14:31 PM »
You guys make some very good points. And yes I will likely miss it ... But I have a  smaller Magnetic Tank bag that  holds all my all my nik-naks.The previous owner had broken the latch and even with a clever repair it still was never as good as new. Plus the main reason was the handle bars back 1" and up anther 1/2". That gives me more upright riding position.
« Reply #17 on: January 06, 2015, 06:43:59 PM »
It's a mini George Foreman. You won't miss it unless you have to have your sandwich warm.
Offline zarticus
« Reply #18 on: January 06, 2015, 08:46:07 PM »
I bought the earlier glove box set up off ebay cheap & will be installing it on my 2012 this weekend, 2 glove boxes are better than one  :chugbeer:
« Reply #19 on: January 07, 2015, 03:44:41 AM »
There has been some success with insulating the underside of the box.
