Author Topic: Any maintenance needs with rear wheel off ?  (Read 4011 times)
Offline h2smokin
« on: October 19, 2014, 09:50:22 AM »
Wondering if the torque rods or any other things require maintenance since I have rear wheel off ? I can't find my manual to check. I took a a nail in the tire yesterday so have wheel off now . Thought I may as well do any other things which may need attention other than final drive. Not sure I want to tackle that. Thanks in advance
Re: Any maintenance needs with rear wheel off ?
« Reply #1 on: October 19, 2014, 10:33:05 AM »
Torque rods?  I usually grease up the splines with moly (both rear drive and drive shaft).  I inspect the drive shaft for any issues as well.  You might as well check the rear brakes while you're at it.
Offline h2smokin
« Reply #2 on: October 19, 2014, 12:54:59 PM »
Just pulled the old pads. They were at about 2.4mm. Question that though. Do I reuse that steel plate and white fiber spacer on the new pads or was that for the stock pads only? It clipped right on
« Reply #3 on: October 19, 2014, 12:59:29 PM »
Dunno.  Can't picture what you are talking about, unfortunately.
Offline h2smokin
« Reply #4 on: October 19, 2014, 02:19:00 PM »
Hope this works. Looked on parts fiche and did not see as a separate item
« Reply #5 on: October 19, 2014, 03:49:48 PM »
Can't say as I've seen that before..but then again, I may not have changed my brake pads on the rear.
jirod
« Reply #6 on: October 19, 2014, 04:45:22 PM »
You can reuse those if they are in good condition. I did 3,000 miles ago and had no issues.
Offline h2smokin
« Reply #7 on: October 19, 2014, 07:57:29 PM »
What are they for, noise reduction, squeaking from pads?
jirod
« Reply #8 on: October 19, 2014, 09:50:46 PM »
Dunno for sure but the fiber sheet might be an insulator to avoid overheating the calipers/ piston seals. Anyone has a better theory? I did not find them on the front brakes, though.
« Reply #9 on: October 20, 2014, 04:34:16 AM »
Yes, reuse them. They're there for a bit of heat insulation between the pads and the calipers. They were a bit tricky getting them to stay together when I reused them on my EBC pads. They didn't seem to fit as tight on the new pads as they did on the stockers.
« Reply #10 on: October 20, 2014, 04:35:46 AM »
You may not have?    ???
Either you did or you didn't. You might want to write stuff like that down eh, Sunny Jim?
Offline h2smokin
« Reply #11 on: October 20, 2014, 05:13:31 AM »
That makes sense. They weren't quite as snug but went on with no issues with the ebc pads thanks
« Reply #12 on: October 20, 2014, 06:34:09 AM »
I would but I'd lose that...
