Author Topic: I've decided to switch from liquid gasolne to vapors...  (Read 10475 times)
Offline Rembrant
« on: September 25, 2014, 01:11:36 PM »
200 miles to one gallon?
What is not to like about this method?
Gas saver dodge running on fumes
Re: I've decided to switch from liquid gasolne to vapors...
« Reply #1 on: September 25, 2014, 01:39:53 PM »
 :popcorn:
Offline Cuda
« Reply #2 on: September 25, 2014, 02:31:18 PM »
Yeah I run mine on methane ... but that damm hose hurts when I insert it :o
Gods waiting room Naples
2011 Atomic  Silver
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #3 on: September 25, 2014, 02:53:38 PM »
ahhh, i don't think so. what about little things like a/f ratio, and BTU's... they're running on fumes, too  :P  Steve
Offline Rembrant
« Reply #4 on: September 25, 2014, 03:07:43 PM »
C'mon now Steve...don't go ruining all this with facts and logic...lol.
Rem :o
« Reply #5 on: September 25, 2014, 03:10:41 PM »
I have heard that the most important part to having that work well is the calibration of the system.
« Reply #6 on: September 25, 2014, 04:06:44 PM »
Hard to believe a gasoline water pipe would vaporize fuel better than an engineered injection system. That's exactly what carburetors and fuel injectors do only at carefully calibrated fuel/air mixture.
Offline Cholla
« Reply #7 on: September 25, 2014, 05:42:34 PM »
Carbs and injectors atomize fuel, not vaporize.
Offline Nosmo
« Reply #8 on: September 25, 2014, 07:10:39 PM »
"Hillbilly" use of a plastic gas can for under-hood fuel tank is the type of crap that lead to the end of Blitz:
http://www.facesoflawsuitabuse.org/2012/12/the-last-week-how-lawsuits-doomed-an-american-icon/
Also, these guys need to read up about air/fuel ratios, like SISF said.
http://en.wikipedia.org/wiki/Air%E2%80%93fuel_ratio
Offline connie_rider
« Reply #9 on: September 25, 2014, 09:24:23 PM »
Thinking about it, I guess I'll concede that the thing will run as he has it built.
His video shows that much..
Interesting;
Some early carburetors were simply a sponge or wick that pulled wet gas into the material. (like a wick on a kerosene lantern)
On those early carbs, Air passing into the motor/over the wet sponge drew air/gas mixture into the motor..
Was pretty crude, but it did work in early automotive history...
On his invention, the 3 hoses would limit the amount of air that he can pull into the engine.
I assume he wouldn't have enough volume for higher rpm's. (so his RPM range must be limited)...
And as stated by others,,, the AF ratio, would have to be perfect to work at all...
Thinking out loud; Something like this could work on an engine that runs a constant RPM.
Like a old industrial water pump etc...  But would be a PITA for other uses...
Offline wahrsuul
  • This is personal, stop reading it!
« Reply #10 on: September 26, 2014, 04:13:29 AM »
Constant RPM?  Hmmm, maybe use it to run a generator to power the electric motors in a car?  Kinda like train engines....
1999 C-10: Knee savers, Givi trunk, Rifle windshield, KB risers, K&N...and counting...
What did I do to deserve this life?  And how do I do it again?
« Reply #11 on: September 26, 2014, 06:14:18 AM »
Interesting;
The Wright Brothers engine dripped fuel onto a hot plate. But that engine only made about 9hp.
Offline leyenda30
« Reply #12 on: September 26, 2014, 10:30:24 AM »
Smoky Yunick from nascar built a vapor system for his Ford Festiva and was featured in Popular Mechanics in the early years.
http://forums.vwvortex.com/showthread.php?5778590-SmoKy-Yunick-s-hot-vapor-engine
08 Kawasaki Concours
05 Honda VTX
07 Husky SM610 sold
« Reply #13 on: September 26, 2014, 12:42:37 PM »
Car brings back memories, a gal in wilkesboro NC had one and put the Ferrari kit on it.  The car was a flop but she was fine as wine.
« Reply #14 on: September 26, 2014, 12:48:44 PM »
OMG, a Fiero!  These were the cars that caught fire weren't they?
« Reply #15 on: September 26, 2014, 02:45:36 PM »
I don't remember those getting that moniker but Ford Pintos certainly did. Of course there were not that many of those that actually caught fire either but it turned into a media circus.
« Reply #16 on: September 26, 2014, 03:23:12 PM »
The early model was known for engine fires.  I seem to recall that the insurance rates for these vehicles went through the roof but I can't prove that as my memory is one of the least reliable things about me.
Language is a bit salty at times...
Fiero on Fire
http://en.wikipedia.org/wiki/Pontiac_Fiero
Feiro catches fire
« Reply #17 on: September 26, 2014, 03:25:59 PM »
Might have been something with the toxicity of the fires if memory serves.
« Reply #18 on: September 26, 2014, 03:30:30 PM »
Cause it was made out of plastic body panels?  Again, another great idea from GM.
« Reply #19 on: September 26, 2014, 04:15:06 PM »
Interesting- I know the Fieros were a little.... odd but did not realize they had that 'burst into flames' trick.
That video sorta' looks like a BMW final drive burning up only bigger.  ;) ;D
<snip>
