Author Topic: KIPASS problem solved  (Read 18889 times)
Offline bongo
« on: September 20, 2014, 08:01:30 AM »
For months now I`v  been suffering with a problem with the KIPASS ignition switch not working properly. The only way I could switch the ignition on was to bash the top hat, with a gloved hand, or knock the side of the ignition switch with a spanner and wait for a click before I could turn the ignition on.
First of all I took the side cover off the switch to revel the solenoid and give that a good clean with some electrical contact cleaner, but no joy still same problem.
Then I put some 3in1 into the key slot but nothing. Then I noticed that the top ring moved up and down and under the piece of ring that sticks out to the left at 9 o`clock there is a micro switch that had become stuck. After a bit of gentle prodding with a small narrow screwdriver and some electrical contact cleaner and some 3in1 the micro switch is now free and the KIPASS switch top hat is now activated with a slightest touch and not a bashing as before.
Hope this helps anyone who is having a problem with their KIPASS ignition switch.
Ali
GTR1400
2Infinity&Beyond,Back4Tea!!!
Offline Racer Boy
Re: KIPASS problem solved
« Reply #1 on: September 20, 2014, 11:03:58 AM »
That is some great information. Thanks for sharing that!
« Reply #2 on: September 20, 2014, 12:05:49 PM »
A big Welcome, Bongo!  Glad to see you here!  What year is your bike?
« Reply #3 on: September 20, 2014, 12:35:59 PM »
Yeah, the 'sticking activation' switch has been a problem since '08. Kawasaki came out with a quasi- fix on later models, and retrofits the earlier one but it does not eliminate the problem, it merely reduces the incidents of it.
There are several work- arounds for this problem, starting with the famous "K- rock" which is used to beat on the ignition switch housing. I also sell a commercial work- around to prevent the bike from being stuck, along with the rider.
A Google search on stuck switch on C-14 will yield a LOT of information about this problem and the various solutions.
Offline bongo
« Reply #4 on: September 20, 2014, 01:59:15 PM »
 2008 with 27,000 fantastic miles on the clock   ;D
Ali
GTR1400
Offline bongo
« Reply #5 on: September 22, 2014, 10:33:59 AM »
It would seem this micro switch might  be the cause of a lot of peoples KIPASS problems and their not been aware that the switch is even there. It could be its not the spring or solenoid but this hidden micro switch that's been the root of the problem all a long,  getting crudded up and sticking.  This micro switch when the top hat is pushed down is what activates the KIPASS and allows the ignition to be turned on to start the bike.   At the end of the day its just a case of keeping this micro switch clean and  free. No need for work around mods and extra switchs to trick the KIPASS.
Simple as that.
Ali
GTR1400
« Reply #6 on: September 22, 2014, 11:27:41 AM »
You are 'discovering' seven year old information. It is great that you are investigating and everything but really, there is a lot known about this already.
The next step is to wonder what Kawasaki is going to do about this? Well, let's skip ahead to 2011  ::)  and see: ah yes, they replace the activation switch's return spring with a stronger one. By the way, this is undocumented by Kawasaki; there is no part number nor have they made this knowledge available but quite a few people have had this service performed.... at no charge because it is simply Kawasaki's way of trying to quietly and inexpensively solve a problem without alerting all C-14 owners to this problem. Now, how does the new spring work.... does it solve the problem? No, it merely reduces the instances of it happening. The cure would be to mechanically connect the key mechanism with the switch actuator so that the switch can be uncoupled directly, no matter how badly it sticks closed.
But again, all this information is out there and readily available. You are "discovering" some really old data and not quite making the best guesses as to how to solve this issue, all in my opinion of course.
Simple as that.
« Reply #7 on: September 22, 2014, 03:12:44 PM »
Oh, and by the way: this is not quite correct for the multiple people that this switch has stranded. I suggest anyone interested do a Google search on the words "stuck" and "KiPass" for more (much more) data on this issue. When the switch sticks and cannot be released, it will strand the bike and rider.
Simple as that.  ;)
<snip>
Simple as that.
Offline bongo
« Reply #8 on: September 23, 2014, 06:10:30 AM »
Simple as that.  ;)
Yes I found plenty of info on the internet about tapping the top and side of the switch, plenty on people changing the springs for stronger ones, lots on faulty  solenoid, there's even a video on Youtube by Brad Harrison posted in 2013 (https://www.youtube.com/watch?v=otvC_AlqxUI) in which at the end he concludes there is something else at fault other than the solenoid,  I think if he had have found this micro switch his video would have ended more positively.
  I could find absolutely no info on this micro switch on the internet and wanted to get it out there, is`t that what these Forums are about sharing info. Yes the switch will most probably play up again in the future and be a bit of a nuisance, but now I know where to look and now as part of my routine maintenance make sure that I give the switch a squirt of WD40 or 3in1. Hopefully this will help someone else not getting stranded they will think to give the ignition switch at tap on the side and get the top hat out then they can get at the micro switch to make sure it free and get some WD on it and hopefully they`ll be on their way again. Or it saves them spending loads of pounds or dollar`s when there`s no need.
 I take your point about plenty of people been left stranded I been one of them, but remembered reading about tapping the switch and waiting for the click to be able to turn top hat which got me home. Then the KIPASS started to play up more regularly so I decides to ring  a main Kawasaki dealer here in the UK, they wanted the bike for 2 hours to investigate at £60 ($98) plus VAT (tax) per hour with no guarantee they could solve the problem and I might be looking at £650 ($1,000) plus VAT and labour for a new ignition unit. Kawasaki UK also thought it was a dodgy solenoid and no they would`t help as the bike is so far out of warranty.  I could have spent hundreds of pounds or dollar`s on something that just needed a penny (cent) squirt of WD40 on a regular basis.
Its a simple fix that can save loads of frustration and money.  ;)
The pics show where this micro switch lives, you can just make it out under the metal tag. This can get stuck down and needs to be teased with a narrow screwdriver and a squirt of WD40 to free it.  Make it part of your maintenance routine to check that its free, if you have your FOB with you as you to touch the micro switch you can make it out clicking away which shows its free.
« Last Edit: September 23, 2014, 07:12:19 AM by bongo »
Ali
GTR1400
Offline clogan
« Reply #9 on: September 23, 2014, 09:44:03 AM »
Good info, Bongo!
Thanks for sharing. I'll be sure to give it a squirt from time to time.
2010 Neptune blue C14
2009 blue KLR
2013 DRZ400
« Reply #10 on: September 23, 2014, 11:57:22 AM »
Just a thought but you might want to do a bit of research before putting WD- 40 inside the ignition switch assembly. The stuff has a tendency to gum after a period of time.
Best of luck whichever way you go though.
Good info, Bongo!
« Reply #11 on: September 23, 2014, 05:05:52 PM »
I am not a fan of WD40 in locks (and similar mechanisms), at all (which has been expressed in several threads lately).  Better to use a contact cleaner to clean it out, then something like a graphite or PTFE spray which will evaporate "dry", leaving no oil to attract/hold dust/dirt.
« Reply #12 on: September 23, 2014, 05:09:38 PM »
And contact cleaner attacks some types of rubber and plastic so that may come with a price tag as well.
You folks know I am not one to scream 'the sky is falling' but I would suggest people be careful and think about what is sprayed down into that metal / plastic / PC board assembly. It might come back to bite you.
« Reply #13 on: September 23, 2014, 05:18:18 PM »
Good point.  Personally, I avoid any type of solvents when possible and just use dry spray lubes.
But here is an example of a contact cleaner that specifically says it is plastic and rubber safe... ironically, it is a WD40 brand :)
http://www.wd40specialist.com/products/contact-cleaner/
« Reply #14 on: September 23, 2014, 05:21:45 PM »
Yep, a dry, non- conductive lubricant would be best (graphite and most lock lubes do conduct electricity and would be poor choices for this application). The one to watch out for, IMO, is silicone which IS a dry lube but unfortunately it is delivered in a wax based vehicle. It <seems> to be a dry lube but it is not, at least none of the brands I have tried.
Offline Rembrant
« Reply #15 on: September 23, 2014, 05:37:33 PM »
Brake Clean baby!!...Large high pressure cans with high flow nozzles that will spray 3 feet and empty a full can in about 60 seconds...lol.
Not sure if anybody noticed, the key section on the first gen C14's (as shown in the pictures earlier) is not nearly as open on the newer bikes. Kawasaki put shields in there later on. I expect lubing that button on the newer C14's would be difficult (with external sprays).
Rem
« Reply #16 on: September 23, 2014, 06:04:15 PM »
Don't laugh- my best friend (a master mechanic) tells me horror stories of people he has worked with doing exactly that kind of thing.... scary.
« Reply #17 on: September 23, 2014, 06:10:15 PM »
Perchloroethylene....better living through chemistry.  :)
Offline Rembrant
« Reply #18 on: September 23, 2014, 06:15:17 PM »
Don't even go there...lol. That stuff is nasty!
Back when I was doing laundry equipment service, I remember holding my breath while sticking my head in those dry cleaning machine drums...lol. Used to be a two man job to fish the wires (from underwire bras) out of the bottom of the machines...lol.
Oh, and grab a handful of one of those dry commercial soaps to clean you hands with....THAT felt good in the nicks and cuts...lol. It was like washing your hands with ground up and broken glass...lol.
Rem
« Reply #19 on: September 23, 2014, 06:22:45 PM »
We used it at IBM Manassas as a cleaning solvent..  We called it Perc.  IBM had a leak of it that migrated into some local wells.  They've been gone from that site for awhile and they are still involved in monitoring and clean up efforts..
http://www.epa.gov/reg3wcmd/ca/IBM_Manassas_V2.html
