Author Topic: '11 Glovebox Panel Cracked...  (Read 7870 times)
Offline RBX QB
« on: September 12, 2014, 02:16:43 PM »
Anyone seen this failure mode yet? Bike has been dropped a couple times (but the Canyon Cages took it like a champ), and I've never dropped anything onto that panel. Only thing I can think is that the action of closing the glovebox repeatedly over the past 3 years caused the cracks to develop (flexing over and over).
Actually, I didn't know I had 2 cracks until I took the panel off to fix the large one. Only thing holding it together are the screws for the grip heater switch.
Any good epoxies or glues you guys would recommend?
2011 Concours 14 ABS
Re: '11 Glovebox Panel Cracked...
« Reply #1 on: September 12, 2014, 04:44:19 PM »
 :yikes: That bites. Haven't seen that failure before. I've had my top left faring off many times. I've modified the glove box so I can open it without the bike on and therefor open it all the time. No problems so far.
Offline clogan
« Reply #2 on: September 12, 2014, 06:25:47 PM »
same here.
2010 Neptune blue C14
2009 blue KLR
2013 DRZ400
Offline jtk1531
  • Country: my
« Reply #3 on: September 13, 2014, 01:56:21 AM »
my right side panel cracked at the bolt hole area... i'm planning to get a new panel rather than fix it. had some brake fluid leaks previously (which flowed into the bolt hole), and the panel had some white discolouration that couldn't be removed.
i do park the bike daily under the sun at office. so it could've been a combination of the sun and heat that caused the cracking.
« Reply #4 on: September 13, 2014, 06:38:30 AM »
Snip...
JB Weld!     :thumbs:
sailor_chic
« Reply #5 on: September 13, 2014, 07:24:03 AM »
I have very good luck using this stuff. It has a been quite useful for me with many projects.
http://www.loctiteproducts.com/p/13/6/epxy_5min/overview/Loctite-Epoxy-Instant-Mix-5-Minute.htm
Offline rocknrod
  • 2013 C14 - Blue
« Reply #6 on: September 13, 2014, 08:31:39 AM »
Never used it but Eastwood has some great products like this: http://www.eastwood.com/tpo-teo-and-pp-plastic-welding-kit-80w-iron.html
Not sure what the actual part costs and time to repair it would be. Probably easier to use the Loctite product though.
Master Chief, US Navy, Retired
2013 C14 Blue, Fenda Extenda, Radiator Screen, HeliBars, Glove Box Mod, 3M paint Protector, Rostra Cruise Control, TechSpec Tank Grips, Lowering Links and Side Stand, Front lowered, Lowered center stand, Balwin Seat.
Offline rotorbike
  • Country: ie
« Reply #7 on: September 13, 2014, 11:11:34 PM »
This panel was broken on a damaged 12 I bought and I repaired it using Plastex. Couldn't recommend the product enough. Easy to work with and a really strong repair.
http://www.plastex.net
Offline Scaffolder
« Reply #8 on: September 14, 2014, 05:43:25 AM »
I think my 2010 did that. Not sure which side. They fixed it under warranty.
Joel from Maine.
« Reply #9 on: September 15, 2014, 06:59:59 AM »
If I were to try epoxy I would cut a piece of aluminum sheet or even thin but stiff plastic of some kind as a backing in a shape like this:
An add it under the faring. would cause it to be lifted slightly under the fastener but it is the only way to make the fix strong enough.
« Reply #10 on: September 15, 2014, 07:11:13 AM »
Befor I'd do anything, see if Mama Kaw will replace it under warranty.
But if they will not, I'd agree with several of the suggestions on how to fix it.
Offline RBX QB
« Reply #11 on: September 15, 2014, 12:43:25 PM »
Thanks for the suggestions.
I hadn't thought about seeing if Kawi will cover it, but it's free to ask (other than my time and gas to head to the dealer). If that doesn't work, I'll apply ALL of your suggestions into one monstrous repair.
« Reply #12 on: September 15, 2014, 12:52:21 PM »
I paid 20-30 for a whole new piece, drama free repair  ;D
« Reply #13 on: September 15, 2014, 01:01:58 PM »
$30 would be a no brainer for me. I expected the panel to be a lot more expensive.
Offline RBX QB
« Reply #14 on: September 15, 2014, 02:25:29 PM »
Ditto.
ebay?
