Author Topic: Waterproof wire connectors  (Read 8493 times)
Offline RFH87_Connie
« on: August 19, 2014, 05:18:51 AM »
Not exactly the correct location to post this, but they could be used on the bike just as well.  My boat motor has a "black box" with about 10 wires going to it, all with those clear silicone (plactic?) waterproof connectors on them to connect it to the wire harness.  I don't think these have to be waterproof anyway, as they are up under the engine cover and protected.  4 of the heavier gauge  (14-16ga?) connectors are burned black and melted pretty bad (like my old GL500).  I can see this going bad as soon as it goes back in the water.  Does anyone know where or who sells appropriate connectors to replace these?  The boat shop was no help as they just wanted to sell a new harness and box.  I have plenty of slack in the wiring still, I just can't find a decent connector.  I thought about soldering but am undecided.  I also searched the web but get way to many to look at that are just junk.  I do have a Grainger's near me but haven't stopped by to ask (didn't see them on their website).
Offline tweeter55
  • Ride Hard...Ride Safe
Re: Waterproof wire connectors
« Reply #1 on: August 19, 2014, 05:43:38 AM »
Beings you have a Grainger close by check these out. I know the talk (I don't necessarily disagree with it) about crimp connectors, but I have used these and they do work. Can shrink them with a match.
http://www.grainger.com/product/3M-Butt-Splice-Connector-3HY92?searchQuery=3hy92
« Reply #2 on: August 19, 2014, 05:47:08 AM »
Thanks.  Maybe I should be more clear as I have a boxes of those in blue, red, and yellow.  I am hoping to use connectors that can be pulled apart if needed (male and female ends), not the permanent type.  Otherwise, I would just solder.  They can be seen in the upper right of the pic.  They are also the same in the lower center.  The water is from me degreasing it.  It is usually never wet inside here.
jirod
« Reply #3 on: August 19, 2014, 06:10:48 AM »
I buy them at any auto parts store, fill them with silicone grease for extra protection, sometimes put heat shrink over them.
Offline tweeter55
« Reply #5 on: August 19, 2014, 10:28:29 AM »
Those are looking about right.
Offline tweeter55
« Reply #6 on: August 19, 2014, 10:29:51 AM »
 :banana :banana :banana :banana :banana :banana :banana :banana :banana :banana
« Reply #7 on: August 19, 2014, 12:01:27 PM »
I think I have found something I like.  The leads that are burned are coming from the stator and charging system as near as I can tell so there would be high amperage and any resistance would be bad.  Two of these from the local hobby shop should do the trick.
http://secure.hobbyzone.com/catalog/HZ/eflite/eflite_connectors/EFLAEC303.html
Offline VTer Bob
« Reply #8 on: August 19, 2014, 05:52:38 PM »
I've used a pile of these on my old KZ's.
http://miniurl.com/668bc
Check the next to last row...
Offline fred-houston
« Reply #9 on: August 20, 2014, 03:58:52 AM »
In the past, I have used Posi-Locks  http://www.posi-lock.com/posilock.html
To waterproof them, I just use shrink tubing.  If I ever need to take them off just simply cut the shrink tubing.
I have used these connectors for years and can not ever recall one of them coming apart.
2001 BMW R1150GS
1999 C-10 (Semi Naked) EFI
« Reply #10 on: August 20, 2014, 05:18:22 AM »
In the past, I have used Posi-Locks  ...  I have used these connectors for years and can not ever recall one of them coming apart.
Nice.  I forgot about those.
And Bob, I can't view your site at work for some reason.
Offline dboogie2288
    • Beginnerbikers.org
« Reply #11 on: August 20, 2014, 02:10:35 PM »
Definitely +1 on the posilocks. They are expensive as hell though, so when they say they are reusable, REUSE THEM!  8)
« Reply #12 on: August 20, 2014, 02:49:43 PM »
I'm going to have to give them a shot. Maybe this:
http://www.jpcycles.com/product/360-375
« Reply #13 on: August 20, 2014, 04:31:33 PM »
Offline dboogie2288
« Reply #14 on: August 20, 2014, 08:34:43 PM »
Molex(like) connectors are nice, but crimping them sucks. You have to have the right tool to do it, and if you bought a crappy crimper at radioshack, that aint the right tool. When I converted my givi e52 into a powerhouse I used a 12 pin molex connector for the harness and its connected under the seat. I dont really need it to be any more weatherproof, but I can always wrap it in elec tape.
« Reply #15 on: August 21, 2014, 05:47:16 AM »
Thanks gPink.  I browsed their site and found the answer.  Looks like this place carries the clear sheaths and connectors that i'm looking for.  It may sound a little overkill, but the connectors on this motor are notorious at burning the connectors when a little resistance is created (it's the charging system).  A few are already pretty far down that path.  I'll solder and crimp the new ones.  Breaking down on the side of the road is just a little different than breaking down in the middle of the river with a literal "boat load" of people.
Covers:
http://www.easternbeaver.com/Main/Elec__Products/Connectors/Sheaths/sheaths.html
Terminals:
http://www.easternbeaver.com/Main/Elec__Products/Terminals/Open_Barrel/open_barrel.html
« Reply #16 on: August 21, 2014, 06:05:58 AM »
For extra protection you might coat with dielectric grease before you snap them together.
Offline GeeBeav
« Reply #17 on: August 21, 2014, 09:50:51 AM »
This is true for any connector or terminal. You need a real crimper, the cheap ones just flatten the terminal onto the wire. This is not a good connection as far as low-resistance or longevity.
« Reply #18 on: August 21, 2014, 10:14:02 AM »
Never fear - I got dad's 40 year old Mac Tools crimper in the box that is well up for the task.  And I do like (and use) the dielectric grease on this type of connection.
« Reply #19 on: August 21, 2014, 10:58:24 AM »
You may know this but those contacts are double- crimp types. They require a crimping tool that will both crimp the terminal onto the wire but also a larger crimping station to crimp the last part of the connector onto the wire's insulation.
Covers:
Terminals:
