Author Topic: Just looking for some answers [tire sizes]  (Read 10930 times)
Offline aspire61
  • 08 concours + 85 madura 1200
« on: August 10, 2014, 07:25:16 PM »
heh all:
I just changed out my rear tire to a 190/55 Pirelli Angel ST. The feedback in the forum suggests better handling with a 55, and I notice it bites into the corners better than my previous 50 tire. Does anyone know the reason for this? I think I fell asleep in physics class that day. Also- do you recommend keeping a 70 up front?
chrs-mat
« Last Edit: January 14, 2015, 05:12:14 PM by maxtog »
No mans opinion is entirely worthless- even a broken watch is correct twice a day.
Offline Daytona_Mike
Re: Just looking for some answers
« Reply #1 on: August 10, 2014, 08:01:18 PM »
heh all:
chrs-mat
A 55 on a 195 tire is almost 10mm taller. Most likely you  changed your old tire because it was worn out. Going from an old tire to a new tire is another 4 or 5mm.
Anytime you raise the back of the bike up higher , in your case ~ 15 mm it will turn easier. Owners do not  check  their sag adjustment after a different sized tire change. Most people think it is the new tire and that is partly correct  but mostly it is the raising of the rear of the chassis changing the ride geometry.
Also the profile is a little different. The 50 is a little flatter and has a better center contact patch when upright. The 55 is more 'V' shaped and a better contact patch when leaned over.
I have ridden on both sizes . I prefer the 50.
« Reply #2 on: August 11, 2014, 04:06:15 AM »
heh all:
chrs-mat
It might help your cause to modify the subject line with something a bit more descriptive on what you're looking for....
Offline aspire61
« Reply #3 on: August 11, 2014, 06:38:54 PM »
Ha ha-perhaps jim, or maybe most people don't actually know why. I was thinking it had something to do with the gyroscoping effect of the wheel and tire. The smaller the circumference, the greater the speed, the more stable the bike, equals more force required to lean.
Then again, i was out of physics class that day, so maybe it just sounds plausible to me.
Offline datsaxman@hotmail.com
« Reply #4 on: August 11, 2014, 09:11:12 PM »
Speed is speed.  At the same road speed, the smaller tire would have a higher frequency, but...the same speed.
But the rotating wheel has momentum that depends on the frequency AND the radius squared.  So the larger wheel should be more stable, all other things being equal.  Which they *actually* never are, of course.
saxman
161.5RWHP on the dyno
Formerly Silverdammit!
Offline Racer Boy
« Reply #5 on: August 11, 2014, 10:30:31 PM »
The reason why it turns more easily is because the 55 series tire is narrower and has a more rounded profile. The wider and "flatter" a rear tire is, the "slower" the steering is.
The 50 series tire looks cool, but it doesn't help the handling of the bike at all.
My other bike is a Yamaha FZ1, and a lot of guys on those bikes change from the stock 50 series tire to a 55 series tire for the same reasons C14 owners do; the bike steers quicker and easier.
« Reply #6 on: August 12, 2014, 04:08:34 AM »
I really think it would be a good idea to modify the subject line...
« Reply #7 on: August 12, 2014, 04:14:55 AM »
42
« Reply #8 on: August 12, 2014, 11:55:21 AM »
heh all:
chrs-mat
Sure, we know why.... because its a brand new tire, it better grip ....... 8) ???
« Reply #9 on: August 12, 2014, 03:11:50 PM »
What he said.
I think that fact is overlooked by most of us when we get new tires. We make a change in brand, size, type, etc. and feel that going from one width to a different width make a huge difference when really it was the fact that the old, dead, worn out tires were changed for brand new ones. Spoon on some new rubber and it is like a new motorcycle.... but how much of that is due to what change (newness alone or the size / brand change)? The only way to really know would be to have two new tires, one in each size / brand, and use them both for, say, 50 miles and see how much difference there really is.
Still, I like 190/55 rubber on my C-14 better than 190/50 rubber. Tried both sizes in several Michelin and now Pirelli types and prefer the /55s in all types so far.
« Reply #10 on: August 12, 2014, 04:54:27 PM »
You have the power.... go for it!  (No really, it is a good idea)
« Reply #11 on: August 12, 2014, 04:55:25 PM »
Bingo!
« Reply #12 on: August 12, 2014, 06:13:13 PM »
Bingo!
Except for me.  I took a nail (actually it was a drill bit) in a brand new 50. Sunny Steve happened to be riding  with me at the time. I went to a 55 because the 50's were out of stock and i needed a tire quick. So I compared a new 50 to a new 55. If I was tracking the bike I would stick with a 55.  I live in Florida.We need the larger center patch down here . I also  like  that tiny increase in gearing (smaller diameter tire). I also think the profile is better on the 50. It handles better than the 55.
 :thumbs: :thumbs:
Offline aspire61
« Reply #13 on: August 12, 2014, 07:08:27 PM »
Yeah- do it. I was thinking something along the line of  "Physics Teacher  Wanted!
« Reply #14 on: August 12, 2014, 10:32:45 PM »
Yeah- do it.
Well, you have the power too- just edit the first post's subject- that will change the topic/thread.
:)  Or maybe "Tire physics teacher wanted!"
Offline Rembrant
« Reply #15 on: August 13, 2014, 04:48:55 AM »
What he said.
Hey Brian,
I've been saying this all along, and I don't think anybody listens, realizes, or gives a poop...lol. Keeping in mind that, while I do prefer the 50 series 190 rears, I still wholeheartedly agree with your comment above. New tires always feel awesome and make the bike feel brand new....and they should!
So I compared a new 50 to a new 55. If I was tracking the bike I would stick with a 55.  I live in Florida. We need the larger center patch down here . I also  like  that tiny increase in gearing (smaller diameter tire). I also think the profile is better on the 50. It handles better than the 55.
 :thumbs: :thumbs:
I agree with Mike here, and prefer the 190/50 rubber. I have also run 190/55 rear tires and I don't like them personally. I think this whole 55 series rear tire business on the C14 has been blown a bit out of proportion, but as with all things on the internet, I suppose that will happen....lol. Some folks will like 'em, some will not;).
Rem 8)
« Reply #16 on: August 13, 2014, 05:00:09 AM »
We could always start on the cheaper, lighter, rounder, 180/55 series. We haven't had a discussion on that for awhile.  8)
« Reply #17 on: August 13, 2014, 05:01:45 AM »
By the way, still waiting to hear about that ton-up highside.
« Reply #18 on: August 13, 2014, 05:10:30 AM »
Raising the rear of the bike changes the rake and trail.  Since I adjust my sag, I didn't notice a difference with the 55 except being a new tire.  Either way, this bike is very planted in the curves, but doesn't handle quick transitions very well when loaded for touring.
« Reply #19 on: August 13, 2014, 06:09:07 AM »
I've got a 55 on now but I can't tell the difference..
