Author Topic: Numb hands  (Read 4455 times)
Offline mikeb2411
Numb hands
« on: July 26, 2014, 08:26:28 PM »
Hey guys, I notice when riding that I get a numb throttle hand after a while of riding and someone told me that a larger grip would help to alleviate that issue. Any thoughts on that? I'm sure someone has tried a larger grip...does it help and if so, what grip do you recommend?
Mike
Ojai, CA
2016 Black Triumph Trophy SE
Re: Numb hands
« Reply #1 on: July 26, 2014, 09:58:43 PM »
Plenty of threads on that in the forums, check the search function.  Try these:
http://www.zggtr.org/index.php?topic=17306
http://www.zggtr.org/index.php?topic=649
http://www.zggtr.org/index.php?topic=9477
http://www.zggtr.org/index.php?topic=216
Re: Numb hands
« Reply #2 on: July 27, 2014, 06:35:07 AM »
I use Grip Puppies and they work great for me.
Offline rocknrod
  • 2013 C14 - Blue
Re: Numb hands
« Reply #3 on: July 27, 2014, 07:16:45 AM »
Also think about not holding the throttle grip so tight.
Offline jwolffie
Re: Numb hands
« Reply #4 on: July 27, 2014, 11:32:56 AM »
I used to use grip puppies but I ride every day so they wore out sort of fast, I know the new design is better and did last longer, but I finally found the cure for me. I got some soft motocross grips and cut both ends off and stretched them over the stock grips using soapy water, they work great and last a long time.
Black 2011
Full Delkevic no cat, Ivan's Flash, Projector headlights, Dunlop Q3+
Valentine 1 with JBV1 on phone
Re: Numb hands
« Reply #5 on: July 28, 2014, 06:02:10 AM »
for some reason I think it is a common thing that we hold the grip tighter than needed, even the right one. During long rides on the highway I got used to keep an eye on the strain that I subject my hands to, for no good reason. GoCruise was a leap forward, too.
Re: Numb hands
« Reply #6 on: July 28, 2014, 07:24:30 AM »
Maybe try heavier end weights. I have Throttlemiester's, I don't use them for throttle lock but they are outstanding end weights.
Re: Numb hands
« Reply #7 on: July 28, 2014, 07:50:53 AM »
Offline rocknrod
  • 2013 C14 - Blue
Re: Numb hands
« Reply #8 on: July 28, 2014, 08:29:23 AM »
I just started using the GoCruise this past weekend. I like it so far.
Offline PH14
Re: Numb hands
« Reply #9 on: July 28, 2014, 09:38:37 AM »
I have the Throttlemeister as well, I do use it as a throttle lock and it works very well. It is easy to set so you can make speed changes easily and hold the throttle position as well. It is great on a long trip.
Offline Jaxter
Re: Numb hands
« Reply #10 on: July 28, 2014, 10:15:02 AM »
it might be all in my mind but...when I switched to Lee Park gloves the hand numbness was reduced a lot (I estimate that I can go about 3 times farther before needing to relieve my hands)...or maybe I am not gripping as tight as I was when I was wearing the Held gloves...anyway I truly believe that the gloves make a difference00000000
I've Never Had A Better Day
Offline JoeRau
Re: Numb hands
« Reply #11 on: July 28, 2014, 10:32:28 AM »
I have both my hands go numb from time to time, usually not at the same time.  Has nothing to do with the bike.  Happens at my desk, in my truck, while I am cooking...
Maybe it has a lot to do with really bad joints.  I was a bit hard on them in my earlier years, and paying the price now.
2012 C14.  Black
COG member 10990
Offline petepro
Re: Numb hands
« Reply #12 on: July 28, 2014, 05:09:14 PM »
I would agree.   I used to hold on till I got Reactive arthritis.  Now I rest my hands and it not only lessens the vibration but I'm a better rider with a lighter grip.
2012 Concours 14abs - 2013 - Current
2002 BMW R1150R - 2012-2013
1995 Honda 750 Nighthawk - 2001-2009
1984 Suzuki GS1150ES - 1987
Offline basmntdweller
    • The Profile Brotherhood
Re: Numb hands
« Reply #13 on: August 01, 2014, 08:37:21 AM »
My hands, mostly throttle hand goes numb on my morning ride to work nearly every day. Never a problem on the ride home!
Matt
'09 C14
'98 DR-350
'03 Honda CBR600RR track bike
Offline xsv
Re: Numb hands
« Reply #14 on: August 01, 2014, 09:07:39 AM »
There is a lack of information to really work from in your question.  If your neck, back and wrists are in perfect "health" then try some grips, etc.  However, in my late 40's I know I have a couple tweaked discs in my neck.  Your riding position (seat height and risers or lack thereof) may contribute to your issues.
I too experience numb hands.  Adding a cruise control allowed my throttle hand a break and alleviated some of the issue.  My Corbin seat really exacerbated my numb hands until I put on risers.   The Corbin made me "reach" for the bars, putting more pressure on my hands/ wrists.  Removing the butterflys and adding a pipe seemed to increase vibration in my bars and bothered my hands.  Some gel grips essentially eliminated that.
You will need to look at a combination of things combined with your particular issues, if any, to find your solution.
2015 Triumph Trophy SE
Offline PeteTN_zgtr
Re: Numb hands
« Reply #15 on: August 01, 2014, 08:12:44 PM »
The stock grips are hard and small. I use the Original grip buddies with gloves that have the gel padded palm. The gloves have helped on other bikes too. You can try changing to thicker gel grips too. My C14 is pretty smooth compared to all other bikes I've owned. Grips are junk though.
